Cinema4D version 2022.1-XB3-(R4) (Experimental) 23.09.22
Forums: Cinema4D version 2022.1-XB3-(R4) (Experimental) 23.09.22
Moderator: aoktar
Re: Cinema4D version 2022.1-XB3-(R2) (Experimental) 09.08.2022
Postby SSmolak » Tue Aug 16, 2022 6:44 pm
SSmolak Tue Aug 16, 2022 6:44 pm
aoktar wrote:@Smolak,
Probably you're not aware that they are not sliders. It's a text edit attached to slider, and all text GUI elements in C4D that are holding the refresh of the whole UI unless you release the mouse. You can see same behavior if you play with some geometry's parameters.
But with some things this is Octane fault not C4D itself - for example UV mapping - if you move UV island ( in UV editor panel ) and release mouse button after that you will see that in UV window this island stay at the same position but in Octane LV it will move.
SSmolak
Re: Cinema4D version 2022.1-XB3-(R3) (Experimental) 09.08.2022
Postby fpajonk » Wed Aug 17, 2022 2:14 am
fpajonk Wed Aug 17, 2022 2:14 am
Is anyone else getting the "There is no CUDA device which is selected" nonsense on an M1 (Studio 32GB OS X Ventura) and knows how to solve this?
fpajonk
Postby bepeg4d » Wed Aug 17, 2022 6:02 am
bepeg4d Wed Aug 17, 2022 6:02 am
fpajonk wrote:Is anyone else getting the "There is no CUDA device which is selected" nonsense on an M1 (Studio 32GB OS X Ventura) and knows how to solve this?
Sorry maOS 13 Ventura is not supported yet.
You should need to go back to Monterey 12.5 to be able to install this version.
ciao,
Beppe
Postby fpajonk » Thu Aug 18, 2022 2:59 am
fpajonk Thu Aug 18, 2022 2:59 am
Why would switching from Monterey with Metal to Ventura with Metal make a plugin scream for CUDA. That doesn't make any sense.
fpajonk
Postby bepeg4d » Thu Aug 18, 2022 7:01 am
bepeg4d Thu Aug 18, 2022 7:01 am
OctaneX 2022.1-XB3 is the first Metal version based on the same CUDA SDK, so the error message is the same.
We should have to replace the word CUDA with GPU, but the concept is the same, the GPU driver is not finding any valid GPU to work with.
ciao,
Beppe
Postby jiabangshou104 » Thu Aug 18, 2022 2:35 pm
jiabangshou104 Thu Aug 18, 2022 2:35 pm
Why does it show white when the ACES tone mapping is turned on?
ACEs Tone Mapping
LV - HDRI Environment - Visible Editor, Renderer Off - It turns white.
LV - HDRI Environment - Clipping Dark Area.
jiabangshou104
Postby elsksa » Thu Aug 18, 2022 3:44 pm
elsksa Thu Aug 18, 2022 3:44 pm
jiabangshou104 wrote:Why does it show white when the ACES tone mapping is turned on?
I believe someone else recently asked the same question, but I can not remember where.
Long story short, this is to be expected, from the shared information. I'd suggest to always provide screenshots for more explicit troubleshooting.
jiabangshou104 wrote:LV - HDRI Environment - Clipping Dark Area.
What do you mean by that? There should be no clipping occurring. Worth to mention that the RRT + sRGB ODT is known to be high contrast. Additionally, the monitor display quality and fidelity is to take into consideration. It's often a non-professional and non-calibrated monitor, which would mislead the resulted viewed imagery.
elsksa
Postby aoktar » Thu Aug 18, 2022 6:55 pm
aoktar Thu Aug 18, 2022 6:55 pm
ACEs Tone Mapping
It's a bug for current SDK. it hopefully will be fixed on next SDKs. Not on XB3.
Re: Cinema4D version 2022.1-XB3 (Experimental) 05.08.2022
Postby Delizade » Thu Aug 18, 2022 8:18 pm
Delizade Thu Aug 18, 2022 8:18 pm
841131100 wrote:Why does it show white when the ACES tone mapping is turned on?
ACEs Tone Mapping
+1
Yes, definitely there is an issue with that. It's sometimes happening, I guess (for my projects file)
I can't share a sample for now my work is so heavy, may be later I will try to share.
Windows 10 (3090Ti) | MacBook Pro (M3 Max)
Delizade
Postby aoktar » Thu Aug 18, 2022 10:04 pm
aoktar Thu Aug 18, 2022 10:04 pm
ACEs Tone Mapping
+1
Please don't report same things several times. I've already answered it a few times.
PreviousNext
Return to Releases
Fri Apr 19, 2024 2:51 pm [ UTC ]
