Cinema4D version 2021.1.5-(R4) (Stable 2021) 28.06.2022
Forums: Cinema4D version 2021.1.5-(R4) (Stable 2021) 28.06.2022
Moderator: aoktar
Re: Cinema4D version 2021.1.5 (Stable 2021) 15.05.2022
Postby moebius » Mon May 16, 2022 12:52 pm
moebius Mon May 16, 2022 12:52 pm
oh, no!
Why did you changed that position? It's so far away. I prefere HSV and have tp change that so many times. Or is there a way to set HSV permanent?
moebius
Postby LOVEXMEDIA » Mon May 16, 2022 1:54 pm
LOVEXMEDIA Mon May 16, 2022 1:54 pm
Awesome new look to the node editor! I came across a bug that crashes C4D at lease for me. If you add a Comment and delete the title and the text comment it will crash. It has happened every time for me.
I am on S26.014, dual 3090, NVidia driver 512.59
Thank you again for your continued support and I appreciate you and the team! You all are amazing!
LoveyDov3
https://www.instagram.com/lvydov3/
i9-10940x [Custom Loop] • 96GB RAM • 2× NVLinkRTX 3090 FE
LOVEXMEDIA
Postby aoktar » Mon May 16, 2022 2:08 pm
aoktar Mon May 16, 2022 2:08 pm
LOVEXMEDIA wrote:Awesome new look to the node editor! I came across a bug that crashes C4D at lease for me. If you add a Comment and delete the title and the text comment it will crash. It has happened every time for me.
I'll continue to improve the nodes further, it's just a start for the porting.
And this is a crash case with new system when no text used. Thanks for reporting, will be fixed for next.
Postby aoktar » Mon May 16, 2022 2:50 pm
aoktar Mon May 16, 2022 2:50 pm
anklove wrote:Dont know on which version this bug appeared. Materials with camera projection lose alpha and scales weirdly. When generating UVWs from camera projection everything is okay
Which bug really? Plase share a sample for showing what you do!
Postby thanulee » Mon May 16, 2022 4:42 pm
thanulee Mon May 16, 2022 4:42 pm
moebius wrote:oh, no!
I d like to set HSV to default as well if possible!
thanulee
Postby anklove » Mon May 16, 2022 4:43 pm
anklove Mon May 16, 2022 4:43 pm
Here's simple example. There is no alpha with camera projection but when i hit Generate UVW from camera projection everything is okay. But im sure i've used camera projections in octane before.
i7 10700k | Win 10 64 bit | RTX 3090
anklove
Postby aoktar » Mon May 16, 2022 7:01 pm
aoktar Mon May 16, 2022 7:01 pm
Ok your problem is about opacity. There is a problem with that since I've added stacked material support for camera mapping. It's destroying the opacity connection for first material. Fixing it for next build.
Postby aoktar » Mon May 16, 2022 7:03 pm
aoktar Mon May 16, 2022 7:03 pm
dynaraton wrote:Very nice update, thank you.
Can we have the "keep upright" option in the Universal Camera like we do in Stand-Alone?
It is a very quick useful feature.
I can add this option but camera view may not match the output.
Postby thanulee » Tue May 17, 2022 5:37 pm
thanulee Tue May 17, 2022 5:37 pm
Hi I think I found a small glitch with the UI of the new color node.
- The arrow doesnt indicate that we are pointing down when color is open. It's area is also hard to click, needs very precise clicking.
- Same goes for the sliders in HSV mode. They are a bit difficult to click.
- In HSV if value is set to 0, the other sliders are stuck. This is weird as we need to do very specific clicks in a certain order.
Not major things, just something I noticed while i was doing coloring.
Thanks bud!
screencapture: https://www.dropbox.com/s/xuqj443aojny5 ... e.mkv?dl=0
thanulee
Postby dynaraton » Tue May 17, 2022 9:33 pm
dynaraton Tue May 17, 2022 9:33 pm
That's ok, Perspective Correction in the Thinlens Camera doesn't either but it does the trick.
Thank you!
Asus Prime Deluxe II : Intel i9-10900 X : 128GB G.Skill 3600 MHz DDR4 RAM : (2) Nvidia RTX TITANs w/ NvLink : Win10 Pro : Latest Cinema4D
dynaraton
PreviousNext
Return to Releases
Thu Apr 25, 2024 3:29 pm [ UTC ]
