Cinema4D version 2021.1-(R7) (Obsolete) 17.12.2021
Forums: Cinema4D version 2021.1-(R7) (Obsolete) 17.12.2021
Moderator: aoktar
Re: Cinema4D version 2021.1 (Stable 2021) 03.11.2021
Postby AaronWestwood » Tue Nov 30, 2021 2:44 pm
AaronWestwood Tue Nov 30, 2021 2:44 pm
aoktar wrote:
AaronWestwood wrote:But I just wondered if there's any update on this texture bug ive mentioned a few times now? On a project currently which is a large animation where the scattered textures are flickering like crazy as the camera is moving by them (trees). Opening in 2020 and its perfect there, so its just in 2021. The project I attached previously shows this bug so wondered if you've looked at this or identified the issue?
Much appreciated as always :)
AW
Hey,
it's not a texture bug. More like an issue on transmission and looks like a core issue. That should be reported to Otoy team.
Okay on it. Thanks man :)
3D Environment Artist
http://www.artstation.com/aaronwestwood
2 x 4090 // 13900KS // 96GB 5600mHz DDR5 // Windows 11
AaronWestwood
Postby SSmolak » Tue Nov 30, 2021 3:12 pm
SSmolak Tue Nov 30, 2021 3:12 pm
Please report it on main Otoy forum. It will be important to me too.
SSmolak
Re: Cinema4D version 2021.1-(R2) (Stable 2021) 14.11.2021
Postby slepy8 » Tue Nov 30, 2021 3:30 pm
slepy8 Tue Nov 30, 2021 3:30 pm
aoktar wrote:Both are shared to all kernel types, so I haven't added it to overwrite part. It's like a global option in a scene. It's a design choice by me.
So it doesn't work, because it renders D65.
After I click "legacy/flat" and then "Copy to VideoPost" it works.
slepy8
Postby aoktar » Tue Nov 30, 2021 4:48 pm
aoktar Tue Nov 30, 2021 4:48 pm
So it works, no need to any tricks.
Postby slepy8 » Tue Nov 30, 2021 8:30 pm
slepy8 Tue Nov 30, 2021 8:30 pm
aoktar wrote:So it works, no need to any tricks.
Ahmet....
If you click on "Legacy/Flat" and NOT click on "Copy to VideoPost" : NOTHING HAPPENS IN PICTURE VIEWER.
You have to click on "copy to VideoPost" to make it work in Picture Viewer.
slepy8
Re: Cinema4D version 2021.1-(R3) (Stable 2021) 30.11.2021
Postby aoktar » Tue Nov 30, 2021 11:34 pm
aoktar Tue Nov 30, 2021 11:34 pm
Small update(R3) is out for using!
Postby divasoft » Wed Dec 01, 2021 5:24 am
divasoft Wed Dec 01, 2021 5:24 am
divasoft wrote:
aoktar wrote:
divasoft wrote:Hi Ahmet, i tryed to get smooth extinction gradient in vdb generator.
Octane well understand cinema noise and i see smooth noise gradients, but when i try to use cinema ramp octane get just half of container of generator without any gradient.
Octane does not understand cinema gradient shader in vdb generator texture slot? Is any chance to get smooth ramp volume?
it should do that but play with intensity of gradient colors.
Yes, of course I tried changing colors. Have you tried it yourself? It seems to me that no.
As you can see, (please take a look at attached image - first column) at any value of the first color of the gradient, we will not get a smooth fading of the density.
And if i invert points of gradient, octane will interpret density another way (why?). When we reverse the colors of ramp, we expect the effect as if we rotated the volume box 180 degrees on the Y axis.
And even so, all the same, we will not get a smooth fading of the density from 100% to 0%.
Right-bottom image shows a smooth gradient of density, but this is not the correct result, because there should be 100% density in the left corner of the volume box.
Maybe you could fix this issue?
Could somebody answer me? Beppe, Ahmet?
divasoft
Postby slepy8 » Wed Dec 01, 2021 6:32 am
slepy8 Wed Dec 01, 2021 6:32 am
aoktar wrote:Small update(R3) is out for using!
Great, but why did you put 8bit/16bit/32bit options instead od D65/Flat ?
It's confusing.
slepy8
Postby AaronWestwood » Wed Dec 01, 2021 8:27 am
AaronWestwood Wed Dec 01, 2021 8:27 am
It's confusing.
Is there anyway to make 'flat' default also? Its a look I much prefer so will exclusively be using it over D65, so can I lock this in permanently?
AaronWestwood
Postby AaronWestwood » Wed Dec 01, 2021 8:31 am
AaronWestwood Wed Dec 01, 2021 8:31 am
Ive been wanting to see a fix for this for ages also. Gradient gets clamped in the mid point and theres ZERO way around that no matter the gradient settings..
AaronWestwood
PreviousNext
Return to Releases
Users browsing this forum: No registered users and 13 guests
Tue Apr 23, 2024 1:23 pm [ UTC ]
