Cinema4D version 2020.2.5-R3 (Obsolete stable) 16.09.2021
Forums: Cinema4D version 2020.2.5-R3 (Obsolete stable) 16.09.2021
Moderator: aoktar
Re: Cinema4D version 2020.2.5-R3 (Latest stable) 16.09.2021
Postby SSmolak » Thu Sep 23, 2021 2:01 pm
SSmolak Thu Sep 23, 2021 2:01 pm
aoktar wrote:This is not directly related to plugin part. Also not sure it's a bug in Octane core. Even not sure it's a bug or not. Maybe about the profile you choose in OCIO. Best answer will come from @Karl.
Generally all 32bit renders that come from OCIO looks like that. No matter what exactly OCIO profile is chosen.
SSmolak
Postby elsksa » Fri Sep 24, 2021 1:23 pm
elsksa Fri Sep 24, 2021 1:23 pm
SSmolak wrote:
aoktar wrote:
SSmolak wrote:Possible bug :
Exporting to 32bit linear EXR while using OCIO like Filmic ( https://sobotka.github.io/filmic-blender ) generate 8 bit color depth file - not 32bit HDR. While exporting as ACES works fine.
Which format and from where? EXR or Octane-Exr? LV or PV?
From PV. If color space is set to main ACES it works fine - full 32bit output but if color space is chosen from OCIO list it saving as 8bit.
Images are after 32bit exposure correction in external software.
ACES:
OCIO:
Sharing this reply from an other thread, here: viewtopic.php?f=30&t=77601&p=404656#p404656
elsksa
Postby BCres » Fri Sep 24, 2021 2:39 pm
BCres Fri Sep 24, 2021 2:39 pm
SSmolak wrote:From PV. If color space is set to main ACES it works fine - full 32bit output but if color space is chosen from OCIO list it saving as 8bit.
From SSmolak's second shot in this post from the previous page, the OCIO is Rec 709. That may be the problem. Rec 709 is usually defined as an 8bit color space with values of 16-235. I use the OCIO setting in the picture and it matches the ACESCg setting as well. Notice my OCIO/ACES selection. Anyhow, this is what works for me.
BCres
Postby SSmolak » Sat Sep 25, 2021 6:06 pm
SSmolak Sat Sep 25, 2021 6:06 pm
BCres wrote:From SSmolak's second shot in this post from the previous page, the OCIO is Rec 709. That may be the problem. Rec 709 is usually defined as an 8bit color space with values of 16-235. I use the OCIO setting in the picture and it matches the ACESCg setting as well. Notice my OCIO/ACES selection. Anyhow, this is what works for me.
But that problem is with EVERY OCIO profile other than standard ACES even Filmic one from https://sobotka.github.io/filmic-blender. They all give 8bit output just like Octane while using Camera Image corrections.
SSmolak
Postby BCres » Sat Sep 25, 2021 7:14 pm
BCres Sat Sep 25, 2021 7:14 pm
I apologize SSmolak, I see the problem you're having is with ACES configurations other than the ACES official (which is what I use.) My mistake. It was your example using REC709 that threw me.
BCres
Postby zoppo » Sun Sep 26, 2021 6:17 pm
zoppo Sun Sep 26, 2021 6:17 pm
Just a small suggestion: would it be possible to set EXR(Octane) as standard format in the render passes tab?
I always use this (cryptomatte!) but sometimes I forget to switch from EXR and then have to re-render.
C4D 2023 | Win10
zoppo
Postby aoktar » Sun Sep 26, 2021 9:21 pm
aoktar Sun Sep 26, 2021 9:21 pm
zoppo wrote:Just a small suggestion: would it be possible to set EXR(Octane) as standard format in the render passes tab?
Yes if others agree with this!
Postby forward » Mon Sep 27, 2021 7:58 am
forward Mon Sep 27, 2021 7:58 am
I am for this request as well!
forward
Postby thanulee » Tue Sep 28, 2021 7:39 pm
thanulee Tue Sep 28, 2021 7:39 pm
+1
thanulee
Postby Kalua » Wed Sep 29, 2021 6:04 pm
Kalua Wed Sep 29, 2021 6:04 pm
Why not... any disadvantages I am not aware?
C4D 25.117 Octane 2022.1.2 R4, <<2 X 3090 + NVlink>>, Windows 10, X399, AMD TR 1950X, 128 GB RAM, NVIDIA SD 536.67
Kalua
PreviousNext
Return to Releases
Users browsing this forum: No registered users and 9 guests
Fri Mar 29, 2024 8:58 am [ UTC ]
