Cinema4D version 2020.2.5-R3 (Obsolete stable) 16.09.2021
Forums: Cinema4D version 2020.2.5-R3 (Obsolete stable) 16.09.2021
Moderator: aoktar
Re: Cinema4D version 2020.2.5-R3 (Latest stable) 16.09.2021
Postby thanulee » Mon Sep 20, 2021 2:10 pm
thanulee Mon Sep 20, 2021 2:10 pm
I try cloner set to multi instance. I add an effector with color. I use instance color/particle and I add cloner and its not working.
Maybe something with my fields? Im using an object in the fields with point distance. I ll try again if u say its working on ur end and report back. Thanks
thanulee
Postby thanulee » Mon Sep 20, 2021 2:41 pm
thanulee Mon Sep 20, 2021 2:41 pm
Yes it does not work re checked. Attaching scene file.
https://www.dropbox.com/s/2ozhy39d8bn2v ... 5.c4d?dl=0
thanulee
Postby Kalua » Mon Sep 20, 2021 5:31 pm
Kalua Mon Sep 20, 2021 5:31 pm
New behavior I have just noticed: old assets with Blend shaders requiere "roughness parameter" to be reactivated. This can be inconvenient if you deal with over 100 assets in a scene.
Regards,
C4D 25.117 Octane 2022.1.2 R4, <<2 X 3090 + NVlink>>, Windows 10, X399, AMD TR 1950X, 128 GB RAM, NVIDIA SD 536.67
Kalua
Postby aoktar » Mon Sep 20, 2021 6:50 pm
aoktar Mon Sep 20, 2021 6:50 pm
thanulee wrote:Yes it does not work re checked. Attaching scene file.
Not sure what you did but it's not working standard material+standard renderer too
Postby thanulee » Mon Sep 20, 2021 10:58 pm
thanulee Mon Sep 20, 2021 10:58 pm
Haha I broke it big time :)
Well it might be related to having as a field, the same object that I am cloning onto. It shouldnt interfere with anything though, but maybe its that?
Cheers
thanulee
Postby cmittenaere » Wed Sep 22, 2021 9:36 am
cmittenaere Wed Sep 22, 2021 9:36 am
Thanks you for this version,
With 2020.2-r5 I have a problem with multiple vdb.
When 2 vdb are cross I see the volume cage.
It's normal ?
Thanks you
cmittenaere
Postby SSmolak » Wed Sep 22, 2021 11:44 pm
SSmolak Wed Sep 22, 2021 11:44 pm
Possible bug :
Exporting to 32bit linear EXR while using OCIO like Filmic ( https://sobotka.github.io/filmic-blender ) generate 8 bit color depth file - not 32bit HDR. While exporting as ACES works fine.
SSmolak
Postby aoktar » Thu Sep 23, 2021 6:56 am
aoktar Thu Sep 23, 2021 6:56 am
SSmolak wrote:Possible bug :
Which format and from where? EXR or Octane-Exr? LV or PV?
Postby SSmolak » Thu Sep 23, 2021 10:59 am
SSmolak Thu Sep 23, 2021 10:59 am
From PV. If color space is set to main ACES it works fine - full 32bit output but if color space is chosen from OCIO list it saving as 8bit.
Images are after 32bit exposure correction in external software.
ACES:
Screen_czwartek, 23 września 2021_12h44m01s_002_.png (10.79 KiB) Viewed 3018 times
OCIO:
SSmolak
Postby aoktar » Thu Sep 23, 2021 12:38 pm
aoktar Thu Sep 23, 2021 12:38 pm
This is not directly related to plugin part. Also not sure it's a bug in Octane core. Even not sure it's a bug or not. Maybe about the profile you choose in OCIO. Best answer will come from @Karl.
PreviousNext
Return to Releases
Users browsing this forum: No registered users and 19 guests
Thu Apr 25, 2024 11:17 am [ UTC ]
