Directional Plane and Disc Lights
Forums: Directional Plane and Disc Lights
Sub forum for feature requests etc
Postby DartFrog » Tue Nov 21, 2017 6:13 pm
DartFrog Tue Nov 21, 2017 6:13 pm
At the moment, octane does not have directional light support. I do not mean IES, but directional plane and disc lights. Vray, Corona, Fstorm, and probably more, all have directional plane and disc lights, and it makes life so much easier. Do you plan on adding this functionality? If so, when? It can't be soon enough. Currently using IES for any sort of directional light adds so much noise into my scenes, that they become almost un-usable, and then I have to waste hours trying to balance light samples across all of the lights in my scene so that the noise clears up some what faster. Hopefully this will be added soon.
Thank you!
DartFrog
Re: Directional Plane and Disc Lights
Postby paride4331 » Wed Nov 22, 2017 11:06 am
paride4331 Wed Nov 22, 2017 11:06 am
Hi DartFrog,
why not use black body emission or texture emission, what is not functional with them?
paride4331
Postby DartFrog » Wed Nov 22, 2017 7:48 pm
DartFrog Wed Nov 22, 2017 7:48 pm
How exactly would you control the angle of direction of a plane or disc light using the Black body or texture emission? In most other engines it is way easier and user friendly. I've attached a screenshot to display what I mean. In the vray example, the angle is controlled by a linear value from 0-1. In other engines It's in degrees. Either is fine just as long as the functionality is there and clear.
Thank you
DartFrog
Postby paride4331 » Thu Nov 23, 2017 9:24 am
paride4331 Thu Nov 23, 2017 9:24 am
Hi DartFrog,
you could use this solution, without using IES, customizable and noise free.
lux.zip
(88.81 KiB) Downloaded 261 times
paride4331
Postby DartFrog » Mon Nov 27, 2017 4:30 pm
DartFrog Mon Nov 27, 2017 4:30 pm
Thanks Paride, I'm glad to see there's a work around. Is there any chance that there will be a much more user friendly light direction slider in the future? I don't think most people would be able to figure this out on their own.
DartFrog
Postby DartFrog » Mon Nov 27, 2017 11:57 pm
DartFrog Mon Nov 27, 2017 11:57 pm
paride4331 wrote:Hi DartFrog,
Also, would you be able to post the settings you used in the falloff, gradient texture, black body, and material? I'm attempting this in a scene and I can't quite get this working. Thank you!
DartFrog
Postby paride4331 » Tue Nov 28, 2017 10:35 am
paride4331 Tue Nov 28, 2017 10:35 am
Hi DartFrog,
hope this helps.
paride4331
Postby DartFrog » Tue Nov 28, 2017 3:16 pm
DartFrog Tue Nov 28, 2017 3:16 pm
Thanks Paride, that definitely does.
DartFrog
Return to User Requests
Thu Apr 25, 2024 10:49 am [ UTC ]
