Glass is not clear in AO mode
Forums: Glass is not clear in AO mode
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby coilbook » Wed Sep 18, 2019 1:46 pm
coilbook Wed Sep 18, 2019 1:46 pm
For some reason glass is not clear in AO mode when it is in the shadow. Similar bug was before in diffuse mode. using 2019.1
coilbook
Re: Glass is not clear in AO mode
Postby coilbook » Wed Sep 25, 2019 1:19 pm
coilbook Wed Sep 25, 2019 1:19 pm
coilbook wrote:For some reason glass is not clear in AO mode when it is in the shadow. Similar bug was before in diffuse mode. using 2019.1
Hi Paride,
any update on this one?
Also in old versions of octane I could have alpha shadows off and sunlight would still shine through the glass. Now it has to be on all the time.
coilbook
Postby paride4331 » Tue Oct 01, 2019 7:20 am
paride4331 Tue Oct 01, 2019 7:20 am
Hi coilbook,
I added your post to my report, I did it on May 16, 2017.
01 (1).jpg (18.81 KiB) Viewed 275 times
Win 7 / i7 5930 - 32gb / 1 x quadro K620 / 2 x Evga Titan X Hybrid
paride4331
Postby coilbook » Tue Oct 01, 2019 11:59 am
coilbook Tue Oct 01, 2019 11:59 am
paride4331 wrote:Hi coilbook,
Hi Paride,
it was fixed in octane 4 but the problem is back in 2019 version
coilbook
Postby coilbook » Tue Oct 01, 2019 2:14 pm
coilbook Tue Oct 01, 2019 2:14 pm
HEre is the scene
when the object is in the shade glass is not clear in AO mode even with very low AO distance
Also in octane 4 I could turn off alpha shadows and still see objects well lit behind the glass with the sunlight. Now it always msut be on
Thank you
dark glass.zip
(708.47 KiB) Downloaded 18 times
coilbook
Postby paride4331 » Tue Oct 01, 2019 3:14 pm
paride4331 Tue Oct 01, 2019 3:14 pm
Hi coilbook,
I will update my test using your scene from V4 to V2019.
3dsmax.zip
(259.08 KiB) Downloaded 18 times
paride4331
Postby coilbook » Tue Oct 01, 2019 3:46 pm
coilbook Tue Oct 01, 2019 3:46 pm
Thanks. Above is a new scene I attached you can test.
coilbook
Postby paride4331 » Thu Oct 17, 2019 8:17 am
paride4331 Thu Oct 17, 2019 8:17 am
Hi coilbook,
this issue has been fixed in the next build.
paride4331
Return to Bug Reports
Sun Feb 23, 2020 3:06 am [ UTC ]
cron
