Incorrect glass alpha
Forums: Incorrect glass alpha
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Re: Incorrect glass alpha
Postby Scrudje » Tue Apr 16, 2019 3:35 pm
Scrudje Tue Apr 16, 2019 3:35 pm
paride4331 wrote:Hi Scrudje,
I see, yes I suppose something goes wrong, I will ask to developers.
Meanwhile a workaround is creating an environment to use in Octane DayLight refractions/reflecliotions.
Thanks for example, but its not what i want. Your final image have only object mask and does not have alpha(transparency IN glass), glass "bake" red background and its not transparent. If check "Alpha channel" you receive transparent alpha channel but it will cut a part of refractions/reflections and any compose here will not help.
I sell images on microstocks like canva.com and they need PNG with truthful opacity. End user have to drug&drop this png image to its own background without using any blend modes.
The best solution that support team do in this case:
1. Сorrect BUG with the displayed information in Alpha channel
2. User render image with glass only once with passes for compose: beauty,reflections,refractions, object id and alpha/opacity channel mask
3. Than it save it to exr or tiff.
4. Open it in PS, blend passes as he will consider necessary. Group it all.
5. Go to "channels" and take ALPHA/OPACITY MASK for this group.
why still otoy did not make it I do not understand - it is basic functions of any post-production((((
Win 10 64 | Geforce Titan black x2 | i7-5960x | 16GB
Scrudje
Postby paride4331 » Tue Apr 16, 2019 10:55 pm
paride4331 Tue Apr 16, 2019 10:55 pm
I used red light panel then red color is a reflection, not a bake.
paride4331
Postby Scrudje » Tue Apr 16, 2019 11:35 pm
Scrudje Tue Apr 16, 2019 11:35 pm
I was already tired to discuss this problem. If you have communication with developers please send them files which I attached to this message. There everything is clear. Thank you
test.zip
(45.78 KiB) Downloaded 170 times
Scrudje
Postby paride4331 » Fri Apr 19, 2019 10:31 am
paride4331 Fri Apr 19, 2019 10:31 am
Hi Scrudje,
this issue will be fixed on next Octane for 3dSMax release.
paride4331
Postby ramone163 » Fri Apr 19, 2019 12:27 pm
ramone163 Fri Apr 19, 2019 12:27 pm
Thank you
GPU: 980+1080+1080Ti; 3ds max;
Behance portfolio; Handmadefont.com;
ramone163
Previous
Return to Bug Reports
Fri Apr 19, 2024 10:58 am [ UTC ]
