normal rendering error
Forums: normal rendering error
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby coilbook » Sun Dec 09, 2018 3:02 pm
coilbook Sun Dec 09, 2018 3:02 pm
when rendering lots of phoenix particles I get this error in RC7. The new build 4.0 crashes even after 1 frame. You cannot even cancel and see the error message. It renders but has an error at the same time.
here is the error. Not sure how it is out of memory when I use CPU ram
CUDA error 2 on device 2: out of memory
-> failed to allocate device memory
device 2: failed to allocate space for geometry (1)
coilbook
Re: normal rendering error
Postby coilbook » Sun Dec 09, 2018 7:46 pm
coilbook Sun Dec 09, 2018 7:46 pm
also this happens while octane viewport is open due to denoising
CUDA error 700 on device 2: an illegal memory access was encountered
-> failed to download symbol(stats data)
device 2: direct light kernel failed
-> failed to set texture format(__data24__)
-> failed to set texture format(__data26__)
-> failed to set texture format(__data29__)
-> failed to set texture format(__data30__)
-> failed to deallocate device memory
-> could not get memory info
CUDA error 700 on device 1: an illegal memory access was encountered
-> failed to wait for event
device 1: direct light kernel failed
denoiserThread1 : Exited with a error. Restart required
-> failed to unregister pinned memory
-> failed to destroy CUDA event
coilbook
Postby paride4331 » Mon Dec 10, 2018 11:04 am
paride4331 Mon Dec 10, 2018 11:04 am
coilbook wrote:also this happens while octane viewport is open due to denoising
Hi coilbook,
what about your TDR delay?
https://render.otoy.com/forum/viewtopic.php?f=27&t=69912
paride4331
Postby coilbook » Mon Dec 10, 2018 3:15 pm
coilbook Mon Dec 10, 2018 3:15 pm
Hi coilbook,
Thanks I'll change it. Could you please test the scene I sent to you as PM and add phoenix liquid grid that I attached in the post viewtopic.php?f=80&t=69843&start=20. Thank you
coilbook
Postby paride4331 » Mon Dec 10, 2018 3:19 pm
paride4331 Mon Dec 10, 2018 3:19 pm
Hi coilbook,
yes we'll do it.
paride4331
Postby paride4331 » Mon Dec 10, 2018 6:18 pm
paride4331 Mon Dec 10, 2018 6:18 pm
Hi coilbook,
yes we'll do it.
paride4331
Postby coilbook » Mon Dec 10, 2018 6:38 pm
coilbook Mon Dec 10, 2018 6:38 pm
paride4331 wrote:Hi coilbook,
yes we'll do it.
Thank you
coilbook
Return to Bug Reports
Thu Feb 25, 2021 2:30 pm [ UTC ]
