Phoenix ocean/water mesh and octane
Forums: Phoenix ocean/water mesh and octane
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby coilbook » Fri Oct 19, 2018 10:37 pm
coilbook Fri Oct 19, 2018 10:37 pm
For some reason this new octane has problem rendering phoenix ocean mesh or any liquid mesh. One frame it renderers next one it does not. The liquid mesh is missing. Then it can appear and disappear.. Thanks
it has something to do with displacement phoenix texture. I am using 3.11.04 Nightly, Build ID: 2018100328568
scene link https://we.tl/t-80GdtMtHuv
please go to frame 1330 and see with rendering>displacement on and off
coilbook
Re: Phoenix ocean/water mesh and octane
Postby paride4331 » Mon Oct 22, 2018 12:44 pm
paride4331 Mon Oct 22, 2018 12:44 pm
coilbook wrote:For some reason this new octane has problem rendering phoenix ocean mesh or any liquid mesh. One frame it renderers next one it does not. The liquid mesh is missing. Then it can appear and disappear.. Thanks
Hi coilbook,
It seems 3.08 and 6.08 render in the same way your file.
Are you usign 3dsmax 2019? What about using 3dsMax 2018?
paride4331
Postby coilbook » Mon Oct 22, 2018 2:45 pm
coilbook Mon Oct 22, 2018 2:45 pm
Hi coilbook,
Hi Paride,
I am using 2018.4 3ds max. You said "It seems 3.08 and 6.08 render in the same way your file." is the problem related to textures? Were you able to reproduce the problem. It seems that when I xref the liquid grid the problem goes away. THanks
coilbook
Postby paride4331 » Tue Oct 23, 2018 7:27 am
paride4331 Tue Oct 23, 2018 7:27 am
Hi coilbook,
I have no idea because you did not share any texture with your file, so it's a little bit difficult to understand the scene if it is right while rendering.
paride4331
Postby coilbook » Tue Oct 23, 2018 7:50 pm
coilbook Tue Oct 23, 2018 7:50 pm
paride4331 wrote:Hi coilbook,
Hi Paridie
it is not about the textures. If you go to frame 1330 you will see there is no liquid mesh appearing. Thank you
coilbook
Postby paride4331 » Wed Oct 24, 2018 9:00 am
paride4331 Wed Oct 24, 2018 9:00 am
Hi coilbook,
this?
paride4331
Return to Bug Reports
Fri May 29, 2020 11:42 am [ UTC ]
