octane wont load phoenix sim/ octane and phoenix empty grid
Forums: octane wont load phoenix sim/ octane and phoenix empty grid
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby coilbook » Wed Jul 25, 2018 11:59 pm
coilbook Wed Jul 25, 2018 11:59 pm
Not sure if I posted this before but here are two main problems:
1. if my phoenix sim starts at frame 100 and I start rendering at frame 90 once it reaches 100 and above no phoenix smoke is loaded and rendered.
The only way for octane to render smoke sequence is to start rendering at frame 100 or above. Not sure why octane is not seeing phoenix
2. Another problem when Alpha shadows is on and phoenix grid is in the scene even empty phoenix grid cells increase render time 2-3 times. it is almost like octane sees empty cells as glass making rendering very slow
coilbook
Re: octane wont load phoenix sim data/ phoenix and alpha
Postby coilbook » Thu Jul 26, 2018 12:29 am
coilbook Thu Jul 26, 2018 12:29 am
UPDATE:
even without alpha there is a big slowdown when empty phoenix grid is in the scene compared to no phoenix when camera looks at it
UPDATE:
Increasing density in volume texture you can start seeing smoke in empty places of the grid. So empty spaces do contain smoke but its density is 0. Why cannot we make octane not render the smoke when its density reaches 0. it is 100% clear but octane still slows down and tries to render emptiness and even slower when volume step length is low (and i think older octane just ignored invisible smoke)
coilbook
Re: octane wont load phoenix sim/ octane and phoenix empty grid
Postby paride4331 » Thu Jul 26, 2018 8:49 am
paride4331 Thu Jul 26, 2018 8:49 am
Hi coilbook,
I dowloaded the file you shared in PM, I will try to figure it out.
paride4331
Postby coilbook » Mon Jul 30, 2018 1:30 am
coilbook Mon Jul 30, 2018 1:30 am
paride4331 wrote:Hi coilbook,
Hi Paride
were you able to find out anything by any chance? It looks like octane only loads phoenix liquids when octane viewport is opened but during rendering it does not load at all no matter what frame it is set to. Thank you.
coilbook
Postby coilbook » Mon Jul 30, 2018 5:58 pm
coilbook Mon Jul 30, 2018 5:58 pm
Also phoenix grid leaves border when volume medium is used with the Sun
coilbook
Postby paride4331 » Wed Aug 01, 2018 11:59 am
paride4331 Wed Aug 01, 2018 11:59 am
Hi coilbook,
I think this issue is correct, because there is a volume medium inside another volume medium, then add up in the phoenix grid.
What do you think about this my thought?
paride4331
Postby coilbook » Wed Aug 01, 2018 2:03 pm
coilbook Wed Aug 01, 2018 2:03 pm
HI Paride
The slow down only happens when looking through an empty grid. When camera is looking somewhere else there is still volume medium from the sun and no slow down. Hopefully I explained it right.
coilbook
Postby paride4331 » Wed Aug 01, 2018 2:15 pm
paride4331 Wed Aug 01, 2018 2:15 pm
HI Paride
I'm talking about this issue you reported.
paride4331
Postby coilbook » Wed Aug 01, 2018 3:09 pm
coilbook Wed Aug 01, 2018 3:09 pm
HI Paride
I mentioned about it in this post. viewtopic.php?f=80&t=68121&start=10
it is a bug because version 3.08 5.07 does not have this. Thank you
coilbook
Postby paride4331 » Thu Aug 02, 2018 7:49 am
paride4331 Thu Aug 02, 2018 7:49 am
Hi coilbook,
yes, I think you're right.
paride4331
Return to Bug Reports
Wed Apr 21, 2021 7:20 pm [ UTC ]
