v3.08.09 issue named GPU Failure
Forums: v3.08.09 issue named GPU Failure
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby finkaboutit » Tue Jun 26, 2018 10:29 am
finkaboutit Tue Jun 26, 2018 10:29 am
I have big issues with the new stable version (3.08.09). it is crashing with a scene working well in 3.07.
Dialog box tell me there is a gpu Failure and stop the render. I don't understand why.
my driver version is the latest 398.11. i tried to unactive card by card ( i have only two one )..nothing is working..
Thx to help me !.
Here is the octane log:
Started logging on 26.06.18 11:43:08
OctaneRender 3.08.1 (3080100)
CUDA error 2 on device 0: out of memory
-> failed to create context for pinned memory
device 0: failed to pin film buffer
CUDA error 999 on device 0: unknown error
-> failed to deallocate device array
-> could not get memory info
-> failed to deallocate device memory
-> failed to deallocate pinned memory
-> failed to unload module
CUDA error 999 on device 1: unknown error
Failed to free page-locked memory
finkaboutit
Re: v3.08.09 issue named GPU Failure
Postby paride4331 » Wed Jun 27, 2018 9:28 am
paride4331 Wed Jun 27, 2018 9:28 am
Hi finkaboutit,
you could try with Nvidia drivers 388.13, or 391.35.
To get an effective Nvidia drivers installed, you could use DDU Nvidia unistaller drivers, the best way to get a clean installation.
http://www.guru3d.com/files-details/dis ... nload.html
Are you using Windows 10? Did you do Windows 10 Fall Creators Update before reporting Nvidia issue?
paride4331
Postby finkaboutit » Wed Jun 27, 2018 10:21 am
finkaboutit Wed Jun 27, 2018 10:21 am
Hi paride and thanks for your answer.
I'm running under creators update. windows 10 pro build 1703.
Have i to reinstall and staying under build 1603 ?
If i have to do that, i will install the driver version you advise after reinstalling, if not i will use ddu and reinstall the good driver version.
I stay tuned.
Thanks to you.
finkaboutit
Postby paride4331 » Wed Jun 27, 2018 10:52 am
paride4331 Wed Jun 27, 2018 10:52 am
Hi finkaboutit,
some users report issue after upgrade, you could try the Nvidia drivers before windows recover.
paride4331
Postby finkaboutit » Wed Jun 27, 2018 11:11 am
finkaboutit Wed Jun 27, 2018 11:11 am
I have to launch renders now so i can't try today, but i tell you when i reinstall the driver ;).
Thanks another time Paride.
finkaboutit
Postby paride4331 » Wed Jun 27, 2018 1:18 pm
paride4331 Wed Jun 27, 2018 1:18 pm
Hi finkaboutit,
Let me hear from you,
paride4331
Postby finkaboutit » Tue Jul 03, 2018 9:22 am
finkaboutit Tue Jul 03, 2018 9:22 am
Thanks Paride ! It is working ! you rock man !
fucking nvidia driver version !
It would be really helpful to create a forum section with good versions of nvidia drivers or advise them into the releases posts.
Thanks a lot ;)
finkaboutit
Return to Bug Reports
Users browsing this forum: No registered users and 5 guests
Tue Apr 23, 2024 7:49 am [ UTC ]
