Camera imager settings not working in exr format
Forums: Camera imager settings not working in exr format
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby anifex3D » Fri Aug 25, 2017 8:20 pm
anifex3D Fri Aug 25, 2017 8:20 pm
When saving an exr file format the camera imager controls are not transferring to the saved exr. I tried with 3ds max gamma hack and without still does not work. All other formats save the camera imager controls when the file saves. This worked before as we always used .exr file format in the past.
3ds Max 2018 with Octane Render 3.06.4 - 4.39
https://anifex.com/ | Win 10 64Bit | i9 - 9920x -128gb ram | 4x RTX Titan 24gb | 3dsMax 2022 Octane Plugin
anifex3D
Re: Camera imager settings not working in exr format
Postby paride4331 » Mon Aug 28, 2017 8:11 am
paride4331 Mon Aug 28, 2017 8:11 am
Hi anifex3D,
I gueess I don't fully understand what you mean.
Has not changed anything from previous versions; .exr using linear 1 does not retain information about camera imager unless you save in nonlinear tone mapping.
If so, could you share some screenshots about your workflow?
paride4331
Postby anifex3D » Mon Aug 28, 2017 12:27 pm
anifex3D Mon Aug 28, 2017 12:27 pm
See images. Not sure how else to explain it better. Somehow the setting are not correct when saving a .exr file it doesn't matter if you try to save it from the max framebuffer or directly render to a file the .exr is not correct. All other formats, .jpg, .png .tif all keep the correct settings and look. If I uncheck the Nonlinear tone mapping box (which is checked) then it completely changes the image in the live view port not desired.
I am not sure when this difference in the .exr may have occurred as we just recently switched to Max 2018 from Max 2017 and we also made the switch from the older version of Octane 3.06-4.33 to 3.06-4.39. It was working correctly in Max 2017 Octane 3.06-4.33. Thanks.
anifex3D
Postby paride4331 » Mon Aug 28, 2017 1:37 pm
paride4331 Mon Aug 28, 2017 1:37 pm
Hi anifex3D,
Thanks for your screenshots; I do not think it's a 3dsMax or 4.39 issue, I think 3ds max Gamma & LUT setting was changed since your previous setup:
Rendering> Gamma / LUT set up>
What do you think about it?
paride4331
Postby anifex3D » Mon Aug 28, 2017 10:30 pm
anifex3D Mon Aug 28, 2017 10:30 pm
Thanks. :D That was the problem. In Max 2018 by default the Gamma/LUT check box is not checked. I checked it on and the .exr file type now works correctly. Hopefully I can remember to turn that on next year in Max 2019.
anifex3D
Postby paride4331 » Tue Aug 29, 2017 8:28 am
paride4331 Tue Aug 29, 2017 8:28 am
Hi anifex3D,
Happy to hear that!
paride4331
Return to Bug Reports
Users browsing this forum: No registered users and 13 guests
Wed Apr 24, 2024 4:18 am [ UTC ]
