ADDING UVW MAPPING Crashes RENDER WINDOW
Forums: ADDING UVW MAPPING Crashes RENDER WINDOW
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby richardyarlett » Tue Aug 15, 2017 9:44 pm
richardyarlett Tue Aug 15, 2017 9:44 pm
When running a LIVE OCTANE RENDER WINDOW, and you go to add a UVW MAP, it crashes the entire 3dsmax session immediately. It happens consistently every since time. If you remember to pause the live update and then add it, you can get away with it. PLEASE fix this, it is driving me crazy.
richardyarlett
Re: ADDING UVW MAPPING Crashes RENDER WINDOW
Postby paride4331 » Wed Aug 16, 2017 6:42 am
paride4331 Wed Aug 16, 2017 6:42 am
Hi richardyarlett,
I tried your issue but everything seems to work fine.
Could you kindly share a scene (even in PM) where your issue happens by adding UVW MAP?
paride4331
Postby richardyarlett » Wed Nov 08, 2017 5:16 am
richardyarlett Wed Nov 08, 2017 5:16 am
This is still an issue. I just updated to the very latest NVIDIA drivers and 3dsmax 2018 update 3 and Octane last version.
No change. Any attempt to ADD UVW to any scene, even just an empty scene with ONE object, immediately takes down the entire 3dsmax session hard. Can you please look into this asap. It is very frustrating.
It only happens with LIVE VIEWER OPEN, and only if it is running. If you PAUSE the LIVE VIEWER, then add the UVW MAP, and then unpause it, it is fine.
richardyarlett
Postby paride4331 » Wed Nov 08, 2017 10:16 am
paride4331 Wed Nov 08, 2017 10:16 am
Hi richardyarlett,
viewtopic.php?f=81&t=63991#p325974
paride4331
Return to Bug Reports
Thu Jul 02, 2020 10:11 am [ UTC ]
