coherent mode create two-faced effect
Forums: coherent mode create two-faced effect
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby coilbook » Sat Mar 25, 2017 4:15 am
coilbook Sat Mar 25, 2017 4:15 am
Seems like if coherent mode is set to 0.25-0.3 or more it will create a two faced looking characters. In the image attached you can see a line between the left and right sides of the character. We are rendering at 3000 samples and this should be more than enough if we use coherent mode
By te way version 2.x never did this with coherent mode enabled.
Seems like version 3 splits image into 4 parts when rendering
coilbook
Re: coherent mode create two-faced effect
Postby paride4331 » Mon Mar 27, 2017 8:33 am
paride4331 Mon Mar 27, 2017 8:33 am
Hi coilbook,
are you using network render?
paride4331
Postby coilbook » Tue Mar 28, 2017 10:48 pm
coilbook Tue Mar 28, 2017 10:48 pm
paride4331 wrote:Hi coilbook,
yes. we do we have 4 slaves
coilbook
Postby paride4331 » Wed Mar 29, 2017 6:22 am
paride4331 Wed Mar 29, 2017 6:22 am
Hi coilbook,
could you check if "minimize net traffic" is on (screenshot) ?
If so, uncheck it please and make a test render; is your render correct?
paride4331
Postby coilbook » Sat Apr 01, 2017 1:28 am
coilbook Sat Apr 01, 2017 1:28 am
hi it was unchecked. Seems like light grey color is affected the most
coilbook
Postby paride4331 » Mon Apr 03, 2017 10:17 am
paride4331 Mon Apr 03, 2017 10:17 am
Hi coilbook,
disabling coherent ratio, Does your problem persists?
paride4331
Return to Bug Reports
Wed Jul 08, 2020 2:27 am [ UTC ]
