Octane daylight and backplate problem SOLVED
Forums: Octane daylight and backplate problem SOLVED
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby mark0spasic » Sun Mar 05, 2017 6:58 pm
mark0spasic Sun Mar 05, 2017 6:58 pm
I found a bug in OctaneRender® for 3ds max® v3.05 - 4.30 [STABLE] when you create Octane daylight and add inside RGB texture all is good, but when I want to add another texture to Rendering/Environment tab/Texture environment to be able to use it as backplate I can switch between two HDR but I can`t use sun anymore? In standalone I can use two HDR+sun.
I also attached files.
test.zip
(78.9 MiB) Downloaded 62 times
test standalone.zip
(78.87 MiB) Downloaded 60 times
AMD FX 6300, 24 GB RAM, Gigabyte ga-990fxa-ud5, 2x MSI GTX 780 3GB
mark0spasic
Re: Octane daylight and backplate problem
Postby paride4331 » Mon Mar 06, 2017 10:26 am
paride4331 Mon Mar 06, 2017 10:26 am
Hi mark0spasic,
attached a screenshot about sun+hdri workflow.
The following links can be useful:
https://render.otoy.com/forum/viewtopic.php?f=27&t=41933&start=10#p306069
paride4331
Postby mark0spasic » Mon Mar 06, 2017 10:07 pm
mark0spasic Mon Mar 06, 2017 10:07 pm
Thank you paride4331 so I need two suns to be able everything to work as it should. In standalone this is more intuitive than in max.
It would be nice to update manual. ;)
mark0spasic
Return to Bug Reports
Wed Jul 08, 2020 2:21 am [ UTC ]
