Cannot open 1.9 files = crashing 3dsmax
Forums: Cannot open 1.9 files = crashing 3dsmax
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby HHbomb » Wed Dec 16, 2015 9:37 am
HHbomb Wed Dec 16, 2015 9:37 am
I wonder if anybody have same problem, but I can't open old scenes done with octane 1.9 with octane 2.15 installed, this crash 3dsmax when opening the scene....
Not very easy to convert a scene that I cannot open...
Hope there is a solution.
HHbomb
Re: Cannot open 1.9 files = crashing 3dsmax
Postby JimStar » Wed Dec 16, 2015 6:33 pm
JimStar Wed Dec 16, 2015 6:33 pm
This is 3ds Max crash, not plugin's...
This is the reason why internal converter is not possible for this. 3ds Max has such a design of stored data structures that they are inaccessible to the plugin during read/write process. So there is not much the plugin can do to avoid this.
But I can try to look for exact reason in your scene if you give me it. Perhaps some workaround is possible in your case...
JimStar
Postby HHbomb » Tue Dec 22, 2015 1:30 pm
HHbomb Tue Dec 22, 2015 1:30 pm
Hi, Jim thanks for answer.
Unfortunally, I can't send you these scenes as is, my client won't be happy....
Can you give me some ideas of what kind of elements can make this crash occur ? so I can try to give you some parts ?
It could help me a lot.
HHbomb
Postby coilbook » Sun Jan 17, 2016 9:10 pm
coilbook Sun Jan 17, 2016 9:10 pm
same here i wish they can at least grey out the materials that do not work instead of crashing max. So far i found mix material that does it
i think as customers we should not deal with this and otoy should find a seamless conversion and transition to a new version. It is like if I have vray 3 and 10000 materials and I buy vray 4 and nothing works anymore all my textures must be rebuilt or they will crash max
new octane crash2.zip
(6.2 MiB) Downloaded 176 times
coilbook
Postby azen » Fri Feb 19, 2016 1:11 am
azen Fri Feb 19, 2016 1:11 am
Give this script a test, and see if this helps. Be sure to use this script on your scene while the 2.23.2 - 1.9 is installed. The scene should open in 2.23.2 - 2.0 or higher now.
Cheers,
Azen
repair 1.9 materials.zip
(695 Bytes) Downloaded 199 times
azen
Return to Bug Reports
Users browsing this forum: No registered users and 5 guests
Sat Apr 20, 2024 4:34 am [ UTC ]
