About max 26 843 545 poly
Forums: About max 26 843 545 poly
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby olivierve » Tue Sep 30, 2014 4:13 pm
olivierve Tue Sep 30, 2014 4:13 pm
Hi Karba,
there's a problem with the 2.06 version, same data for test between the 1.55 and 2.06: (3dsmax2015)
24 201 860 poly => 2.06 version crash
24 201 860 poly => 1.55 work
Some news about maximum poly and 2.06 vs 1.55 ?
thanks, Oliver
olivierve
Re: About max 26 843 545 poly
Postby olivierve » Wed Oct 01, 2014 4:04 pm
olivierve Wed Oct 01, 2014 4:04 pm
Re,
new test with 2.1 => same with 2.06 => loading failed.
always work with 1.55 !
(about configuration dual Nvidia Quadro K6000)
Hope about good news, Olivier
olivierve
Postby Karba » Thu Oct 02, 2014 7:41 pm
Karba Thu Oct 02, 2014 7:41 pm
olivierve wrote:Hi Karba,
thanks, Oliver
Currently 2.x versions have triangle limitation about 19.173.961 triangles
Karba
Postby olivierve » Thu Oct 02, 2014 7:52 pm
olivierve Thu Oct 02, 2014 7:52 pm
thank you for the information, Karba.
I know it is not easy to discuss about the ongoing development for version 2.x, but is there a change to load more triangle in a near future release ?
Remember i have dual quadro k6000, so I'm frustrated !
Oliver
olivierve
Postby Karba » Thu Oct 02, 2014 7:57 pm
Karba Thu Oct 02, 2014 7:57 pm
olivierve wrote:thank you for the information, Karba.
Oliver
What kind of scene do you render? What is the main triangle source?
Karba
Postby olivierve » Fri Oct 03, 2014 7:43 am
olivierve Fri Oct 03, 2014 7:43 am
I work in digital archive of heritage, especially in archeology.
My 3D models are created by 3D scanning. The density of triangles in the geometry is very important and I can not too much decimated models.
Models from 10 million triangles to 100 million triangles (with huge model MentalRay rendering)
with my test i hoped it'll be possible to load near 50 million triangles with the 12Go vram of the Quadro K6000.
so, i'm frustated with the downgraded triangles power 2.1 (19 173 961) vs 1.55 (26 843 545).
Perhaps i'll need to find a dynamic cameara LOD solution.
If you have more information and ideas, i'll keep !
O.
olivierve
Return to Bug Reports
Users browsing this forum: alexmarks3d and 1 guest
Thu Aug 13, 2020 12:15 am [ UTC ]
