Displacement geometry problem
Forums: Displacement geometry problem
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby vitgaus » Tue Dec 11, 2018 10:54 pm
vitgaus Tue Dec 11, 2018 10:54 pm
I made two identical objects and applied a displacement map to one of them. The most of displacement texture is black, meaning no displacement. The result is unexpected. See pics below. How to fix?
Second picture is same but with opacity map (same texture as for displacement).
The displacement setting are also attached.
vitgaus
Re: Displacement geometry problem
Postby paride4331 » Wed Dec 12, 2018 10:34 am
paride4331 Wed Dec 12, 2018 10:34 am
Hi vitgaus,
you can not work with coplanar surfaces; moreover maybe you have problems with smooth objects, normal and probably some issues with Unwrapping.
you should set mid level to 0.5 best using 32bit texture.
paride4331
Postby vitgaus » Sat Dec 15, 2018 2:17 pm
vitgaus Sat Dec 15, 2018 2:17 pm
Well, those are two independent surfaces, although identical, meaning I can do Unwrapping with no problems. But trick with mid level works fine, THX!
Actually this is the car steer wheel model and I tryed to make stitches with displacement, as shown here:
https://www.behance.net/gallery/7219448 ... riment-CGI
vitgaus
Return to Bug Reports
Wed Apr 24, 2024 5:38 pm [ UTC ]
