Hi HHbomb,
I guess I misunderstood, quick mode allows any update, in which cases you incur into this issue?
samsue wrote:Hi paride4331,
3DS Max - 2021.1 / 23,0 -23.1.0.1314
Whenever I'm rendering with OctaneRender Viewport this issue occurs. It's also something new to me this issue, but it's hard to know whether it's because of the nvidia driver, 3ds max or octane ...
HHbomb wrote:HI, Paride.
Create a fresh scene, make a plane, Open octane viewport, check Quickmode , add an Octane_Daylight.
Hide Daylight in Layer explorer. Still active.
Why do I use Layer explorer to deactivate daylight ? Because Layer explorer is very powerfull, to show or hide a bunch of objects or lights with a clic !
neonZorglub wrote:samsue wrote:Hi paride4331,
Hi samsue,
Sorry about the response delay !
As Paride mentioned, we got puzzled by this issue and couldn't reproduce it..
-Does this happen only while the viewport render window is open ?
-Did you try with max2020 or other version?
-Does the compact editor work fine ?
-Could you backup your octane user config file (octane3dsMaxConfig.cfg)
(octane3dsMaxConfig.cfg can found with User Global settings/Tools/Explore User settings folder, that will open for eg: C:\Users\xxxxx\AppData\Local\Autodesk\3dsMax\2021 - 64bit\ENU\plugcfg_ln)
and try Preset/'Reset default settings' ?
-in Trouble shooting tab, could you turn on 'Enable Extra Log', and check if you see any warning ?
you should have those 3 lines every time you click on a new material/tex :
OctaneTexture::CreateParamDlg()..
OctaneTexture::CreateParamDlg() DONE. (0.078 sec)
uitOnDoneCreateParamDlg(): 0.094 sec
samsue wrote:-seems to have improved, but not eliminated the issue, I need to
close and open again the material editor (not the compact one), so it works again
-i should see this on the "Log Windows" screen?
