OctaneRender® for 3ds max® v4.05 - 6.21
Forums: OctaneRender® for 3ds max® v4.05 - 6.21
Re: OctaneRender® for 3ds max® v4.05 - 6.21
Postby thekwen » Fri Oct 18, 2019 1:34 pm
thekwen Fri Oct 18, 2019 1:34 pm
Try to hear my words, really hear it not just answer it.
I do this job for 20 years and today for the first time in 20 years i had to change my workflow in the middle of my production because octane V3 couldn't render high size any more.
So my advice, make otoy team strongly test updates before release, working with octane is just like playing lottery.
Anyway, i still crash with your settings.
I upload the file in attachment if you want to get an eye on it. (3dsmax 2018)
What driver do you use ?
HF.rar
(236.4 KiB) Downloaded 164 times
thekwen
Postby paride4331 » Fri Oct 18, 2019 1:56 pm
paride4331 Fri Oct 18, 2019 1:56 pm
Hi thekwen,
436.48
Try to use cpu memory in Kernel > Render setting
paride4331
Postby thekwen » Fri Oct 18, 2019 2:36 pm
thekwen Fri Oct 18, 2019 2:36 pm
still crashing, i use the same nvidia drivers, are you on 3dsmax 2018 ?
thekwen
Postby paride4331 » Fri Oct 18, 2019 3:06 pm
paride4331 Fri Oct 18, 2019 3:06 pm
Hi thekwen,
yes, 3dsMax 2017, 2018 and 2019 too.
you could you try to install 436.48 Nvidia driver again.
To get an effective Nvidia drivers installed, please use [DDU Nvidia unistaller drivers](http://www.guru3d.com/files-details/dis ... nload.html) (safe mode unistall), the best way to get a clean installation.
paride4331
Postby thekwen » Fri Oct 18, 2019 3:26 pm
thekwen Fri Oct 18, 2019 3:26 pm
I did a ddu install in safe mode of latest drivers.
I also reinstalled octane after that.
Could you send me the hair and fur files from your pc for 2018 just to see if im not missing something in setup ?
thekwen
Postby thekwen » Sat Oct 19, 2019 12:05 pm
thekwen Sat Oct 19, 2019 12:05 pm
I ask a friend to test Hair and Fur and it was working, with 6.14, so i install it and it works.
Then i upgrade from version to another and now it works even with 6.21.
As i said, octane lottery, this is pathetic.
thekwen
Postby thekwen » Sun Oct 20, 2019 9:20 am
thekwen Sun Oct 20, 2019 9:20 am
Epilogue:
Reopening the same files that was working yesterday, 3dsmax crash ...
Testing ... testing ... to see that when i install 6.20 or 6.21 the hair and fur file works once and once only, after that it crashs ...
Downgrade to 6.14, everything seems to work more than once ...
Octane nightmare ...
thekwen
Postby zerozerozero » Sun Oct 27, 2019 1:13 pm
zerozerozero Sun Oct 27, 2019 1:13 pm
Buraq wrote:Hi,
Another problem with 6.21. When I add the bitmap node, 6.21 is crashing.
Hi, I have the same problem. Have you been helped? Is there a solution? Or again roll back to the old version?
zerozerozero
Postby zerozerozero » Sun Oct 27, 2019 2:17 pm
zerozerozero Sun Oct 27, 2019 2:17 pm
paride4331, hi look please! When you add an image, the program crashes. This is in an empty scene.
zerozerozero
Postby Buraq » Sun Oct 27, 2019 3:15 pm
Buraq Sun Oct 27, 2019 3:15 pm
zerozerozero wrote:paride4331, hi look please! When you add an image, the program crashes. This is in an empty scene.
I already reporded weeks ago. They are ignoring all problem V4 for now!
Buraq
PreviousNext
Return to Releases
Thu Apr 25, 2024 12:48 pm [ UTC ]
