OctaneRender® for 3ds max® v4.02.1 - 6.15
Forums: OctaneRender® for 3ds max® v4.02.1 - 6.15
Re: OctaneRender® for 3ds max® v4.02.1 - 6.15
Postby paride4331 » Thu Mar 28, 2019 9:11 am
paride4331 Thu Mar 28, 2019 9:11 am
perro_abombao wrote:Hi ...I have problems with infinite plane support...an old version file crahes 3ds max, when I try to use it...and native tool in this version doesn´t work...(modifier octane geometry properties)
Hi perro_abombao,
set the plane to movable proxy.
paride4331
Postby solomon » Tue Apr 02, 2019 12:39 pm
solomon Tue Apr 02, 2019 12:39 pm
Will 3DS Max 2020 get support soon?
Solomon W. Jagwe
3D Artist/Animator/Modeler | Independent Film Director
http://www.sowl.com | http://www.galiwango.com | http://www.nkozaandnankya.com
solomon
Postby paride4331 » Tue Apr 02, 2019 1:22 pm
paride4331 Tue Apr 02, 2019 1:22 pm
solomon wrote:Will 3DS Max 2020 get support soon?
Hi Solomon
https://render.otoy.com/forum/viewtopic.php?f=27&t=71217#p360640
paride4331
Postby solomon » Thu Apr 04, 2019 2:26 pm
solomon Thu Apr 04, 2019 2:26 pm
Hi Guys,
I just noticed that some aspects of the Octane objects are missing in this version, which were present in 6.14 ~ where can I find these settings?
Solomon W. Jagwe
solomon
Postby coilbook » Thu Apr 04, 2019 4:08 pm
coilbook Thu Apr 04, 2019 4:08 pm
Hi Paride,
any news about slow material editor? Even typing is slow after using octane viewport and messing with mesh and materials. I 've attached the video\
coilbook
Postby paride4331 » Fri Apr 05, 2019 7:36 am
paride4331 Fri Apr 05, 2019 7:36 am
solomon wrote:Hi Guys,
Hi Solomon,
developers are moving some features to 3dsmax modifier:
https://render.otoy.com/forum/viewtopic.php?f=27&t=70773
paride4331
Postby neonZorglub » Tue Apr 09, 2019 5:28 am
neonZorglub Tue Apr 09, 2019 5:28 am
Hi perro_abombao,
You could try first to disable the infinite plane for your object after loading the scene:
In the standard 3dsmax object properties, User defined tab, there should be a line
octane_special_obj_type = 1
that you can remove, or set '= 0'
You could then try to create a more simple object (eg a plane, with a simple octane material), that you can set a infinite plane.
Also, when loading from an old version (without the modifier), you can keep the 'object special type' : Infinite plane in the octane Object properties, as previously, by turning off
'Move Geometry settings to Octane Properties Modifier' in the 'Prev Versions' tab of global settings.
I hope that helps.
neonZorglub
Previous
Return to Releases
Mon Jun 01, 2020 11:49 pm [ UTC ]
