OctaneRender® for 3ds max® v2.05a (Updated)
Forums: OctaneRender® for 3ds max® v2.05a (Updated)
Re: OctaneRender® for 3ds max® v2.05a (Updated)
Postby 3dgeeks » Thu Aug 07, 2014 5:42 am
3dgeeks Thu Aug 07, 2014 5:42 am
Nice, its good to see regular updates.
It would be good to start another vote for new feature requests, to supercede the one leading up to 2.0.
I would include
- complete matting solution
- better shader integration with max viewport
- access to more of max procedurals such as noises and tiles
- Octane proxy system.
- Net Render manager
- Saving of partial rendered samples, with ability to restart
3dgeeks
Postby merid888 » Thu Aug 07, 2014 12:20 pm
merid888 Thu Aug 07, 2014 12:20 pm
thank you karba, i'll test
W10 x64 Bits, 24 Gb 1866 OC Mghz, P9X79 ws, E5-2670 Xeón, 2.60 Ghz to 3.30 Ghz Overclock, 2 SSD 240 Gb Raid, ThermalTake Water 2, 1 GTX 1080 Ti OC 11 GB ROG STRIX, 1 Power Supply Corsair 750 W.
merid888
Postby JuM » Fri Aug 08, 2014 9:17 am
JuM Fri Aug 08, 2014 9:17 am
Hi Karba.
Random color texture is reassigning each frame and chaging color. I created a forest scene with instancing just a one tree. I gave color gradient map for the leaves. Then gave random color texture to the leaves. Started animated render and its changing the color of the leaves each frame. It could be nice if i would be static colors.
JuM
Postby darkline » Fri Aug 08, 2014 2:30 pm
darkline Fri Aug 08, 2014 2:30 pm
Having serious problems with every release of Octane 2 onwards. Basically a scene that used to render on 1.55 fails everytime in 2.x
I have tried to find the fault by hiding/turning things off in my scene, and discovered it comes down to the VRAM overspilling in 2.x. So I started to delete objects to get the poly count down and did this test - deleted all the fur bar 1 object (it's actually mesh created from fur the fur modifier has been removed). Then ran it in both versions of octane :
2.05a
1.55
You can see that for some reason the same scene is taking over 1GB more in octane 2. Now, I thought this might be due to some of my hidden layers still having hair and fur modifiers on them (even though they are disabled in the stack). So I removed everything in the scene but a single mesh and re-saved the file. To be clear this scene contains just a mesh and a light - no modifiers.
This is the scene opened in 1.55
This is exactly the same scene in 205 :
As you can see in Octane 1.55 the scene takes up 1.4GB and in Octane 2.05 it takes up 2.3GB
This is the same max file simply rendered with the two versions of octane. Since version 2 has been released I cannot open the full file of this character without running out of RAM and octane failing every time.
Windows 7 64bit/ Intel 3930K/ ASUS Rampage IV/ GTX980ti x 2/ 64GB system RAM
darkline
Postby Karba » Mon Aug 11, 2014 2:27 am
Karba Mon Aug 11, 2014 2:27 am
darkline wrote:Having serious problems with every release of Octane 2 onwards. Basically a scene that used to render on 1.55 fails everytime in 2.x
2.05a
1.55
fixed, now it takes the same amount of memory.
wait for a new release.
Karba
Postby darkline » Mon Aug 11, 2014 11:24 am
darkline Mon Aug 11, 2014 11:24 am
Thank you Karba
darkline
Previous
Return to Releases
Wed May 27, 2020 12:31 am [ UTC ]
