Carrara's demo plugin
Posted: Thu Jan 17, 2019 2:35 pm
I wanted to try Octane in Carrara, and installed demo plugin (2.17.0068),but it's not working. Log says
[13:53:10.582] Started logging on 17.01.19 16:53:10
[13:53:10.582]
[13:53:10.582] Flag Type Value Prefix Description
[13:53:10.582] ------------------------- ------- ---------- ---------- --------------------------------------------------------------------------------
[13:53:10.582] apiChangeMgr release 0 "apiChngMgr" Logs ApiChangeManager::update().
[13:53:10.582] apiNetwork release 0 "apiNetwork" Logs all important calls into ApiNetRenderManager
[13:53:10.582] apiNodeSystem release 0 "apiNodeSys" Logs all write operations in the API node system.
[13:53:10.582] apiProject release 0 "apiProject" Logs all important calls into ApiProjectManager.
[13:53:10.582] apiRender release 0 "apiRender" Logs all important calls into ApiRenderEngine.
[13:53:10.582] cudaProf release 0 "cudaProf" Enables general logging of CUDA profiling.
[13:53:10.582] cudaProfDetail release 0 "cudaProf" Enables logging of single CUDA activity records.
[13:53:10.582] logAppendToFile release 0 "" If enabled, logging will be to the already existing log file appended
[13:53:10.582] logFlags release 1 "" If enabled, all log flags will be dumped during startup
[13:53:10.582] logFlushTime release 0 "" The time (ms) after which the log is flushed. If set to 0, the timer based flush will be disabled.
[13:53:10.582] logForceFlush release 0 "" If enabled, every logged line will be flushed
[13:53:10.582] logJuce release 0 "JUCE" If enabled, JUCE logging will go through the logging framework of Octane
[13:53:10.582] logPrefix release 1 "" If enabled, each log line will have a prefix
[13:53:10.582] logTime release 1 "" If enabled, each log line will have a timestamp
[13:53:10.582] logToDebugConsole release 0 "" If enabled, logging will go to the debug console (Windows only)
[13:53:10.582] logToFile release 0 "" If enabled, logging will go to a log file
[13:53:10.582] logToStdout release 0 "" If enabled, logging will go to standard out
[13:53:10.582] subdivider release 0 "subdivider" logs info about the subdivision process
[13:53:10.582]
[13:53:10.582] OctaneRender version 2.17 (2170000)
[13:53:10.582]
[13:53:33.473] ERROR : device 0: failed to find a CUDA binary matching compute model 6.1
[13:53:33.790] Scene contents: 0 primitives, 1 cameras, 1 lights, 0 master objects, 1 master shaders
[13:54:01.632] Scene contents: 4 primitives, 1 cameras, 1 lights, 4 master objects, 40 master shaders
Is there ANY way to try it for Carrara?
[13:53:10.582]
[13:53:10.582]
[13:53:10.582]
