OctaneRender for Carrara 3.08.03.42[Stable and Test]
Forums: OctaneRender for Carrara 3.08.03.42[Stable and Test]
Carrara (Integrated Plugin developed by Sighman)
Re: OctaneRender for Carrara 3.06.00.33[Stable]
Postby orion_uk » Tue Aug 08, 2017 8:12 pm
orion_uk Tue Aug 08, 2017 8:12 pm
protovu wrote:Ok then.......its me!
Wonder what to check.
Could be, the squirrel in my computer needs feeding.
Maybe Simon will suggest a reload of the plugin?
Thank you again for testing. So good to know there are other CarraraOctaners out there.
Best,
Rick
No problem bud, maybe someone else or Sighman will chip in at some point? Not sure who is around these days/not looked yet lol. But do give me a shout any time if you dont find what you need here..like i say, IF i can help i will ;)
http://www.Neil-Isted.com
Intel i7 870/2.93 GHz
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
OctaneRender™ for Blender
Ds pro
OR Standalone V4
Poser Plugin
orion_uk
Postby protovu » Tue Aug 08, 2017 9:43 pm
protovu Tue Aug 08, 2017 9:43 pm
Hi Orion,
Just did a simple test file that did, in fact, work. (Sphere moving in an HDRI scene)
Could be that the files I am trying to use are simply too complicated. I believe that I gave them ample time to load.
Will try again later and give a shout if anything comes of it.
Best,
Rick
protovu
Re: OctaneRender for Carrara 3.06.04.35[Stable]
Postby Sighman » Sun Aug 20, 2017 6:32 am
Sighman Sun Aug 20, 2017 6:32 am
New update posted to this thread.
Uses latest Octane SDK and fixes a performance issue with LiveDB.
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
Sighman
LDB crash
Postby protovu » Fri Sep 08, 2017 8:16 pm
protovu Fri Sep 08, 2017 8:16 pm
Hi Simon,
I am able to duplicate a Carrara/LDB crash by simply scrolling down within the Cloth category. Haven't noticed crash yet in other categories, but duplicated 3 crashes in different files
searching Cloth.
Rick
protovu
Re: LDB crash
Postby Sighman » Fri Sep 08, 2017 8:57 pm
Sighman Fri Sep 08, 2017 8:57 pm
protovu wrote:Hi Simon,
searching Cloth.
Rick
Thanks for the report. I'll look into it. In the mean time, I enabled livedb in the local Db tab. You can try to download materials from there.
Sighman
Postby protovu » Fri Sep 15, 2017 11:29 pm
protovu Fri Sep 15, 2017 11:29 pm
Hi Simon,
On the LDB, today, getting the following message when scrolling down:
"Buffer size is not sufficient".
And, of course, not able to scroll down.
Local DB lets me view, but not download into Carrara.
Rick
addendum......just crashed....But on Carrara reload, now able to scroll down and select in LDB....
.almost: it seems like trying to view the very last, or bottom most Materials, stimulates a crash.
protovu
Postby Sighman » Sun Sep 17, 2017 4:09 am
Sighman Sun Sep 17, 2017 4:09 am
Did you select import from local db?
Sighman
Postby protovu » Sun Sep 17, 2017 10:17 pm
protovu Sun Sep 17, 2017 10:17 pm
Right-click / import seems to work.
I don't know how I missed that.
Thanks. Now I have a new, fast LDB access.
protovu
Re: OctaneRender for Carrara 3.06.04.35[Stable] - shadow control
Postby protovu » Sun Sep 17, 2017 10:41 pm
protovu Sun Sep 17, 2017 10:41 pm
Hi Simon,
I am having some problems with turning off shadows using the Octane Object Layer.
In particular, I would like to use an Octane enabled Spot light in my scene. Really like the controls you have enabled with the Spot.
Both the Spot and the Bulb are showing shadows, despite using the OOL modifier.
Rick
protovu
Postby Sighman » Mon Sep 18, 2017 1:23 am
Sighman Mon Sep 18, 2017 1:23 am
Are you setting the object layer on the object casting the shadow? Setting it on the light will have no effect.
Sighman
PreviousNext
Return to Carrara
Users browsing this forum: Bing [Bot] and 8 guests
Wed Apr 24, 2024 8:32 am [ UTC ]
