Create random textures over instances
Forums: Create random textures over instances
Re: Create random textures over instances
Postby Yugs » Fri Sep 15, 2017 2:34 pm
Yugs Fri Sep 15, 2017 2:34 pm
Would it be possible to have this scripted graph working with an image texture input instead of a string value ?
That way one could, for instance, link an image node with UV transform information directly to the script. I tried to do it but I don't know the first thing about LUA. I just managed to change the string input to a texture one, but all I get is a blank material.
Thanks for this anyway, it comes very handy!
Cheers,
Yugs
Yugs
Postby smicha » Mon Mar 19, 2018 8:49 pm
smicha Mon Mar 19, 2018 8:49 pm
Could you please help and make this script working under V4?
smicha
Postby roeland » Mon Apr 09, 2018 3:00 am
roeland Mon Apr 09, 2018 3:00 am
As far as I can see the script still works under version 4.
Yugs wrote:Would it be possible to have this scripted graph working with an image texture input instead of a string value ?
It's possible to create a similar script with texture inputs, how exactly depends on what exactly you want to achieve. Do you want one image texture input with a bunch of random additional transforms applied to it?
Roeland
roeland
Postby whersmy » Mon Apr 09, 2018 7:58 pm
whersmy Mon Apr 09, 2018 7:58 pm
Would be very welcome.
Would it be possible to create an Amount and Scale input for the scatter node? I would like to reproduce a texture like this on a big surface
Actually OSL should be able to simulate this I think
Octane 2022.1.1 nv535.98
mac pro g5| pentium g2030 iGPU| maximus extreme V| 2x gtx590 - 8gb - SSD - win7-x64- 1500W Silverstone|
x201t - gtx580 - egpu ec
Octane Render experiments
whersmy
Postby roeland » Mon Apr 09, 2018 8:48 pm
roeland Mon Apr 09, 2018 8:48 pm
Yes, this can be done using an OSL texture: You can start from the laminate example here: viewtopic.php?p=326508#p326508
Set the plankAspect to 1.0 for square tiles.
However, this shader will generate a random offset for every row of tiles. To get a regular pattern like in your picture find and replace the lines
    // random offset for each row
    float x = p[0] + noise("cell", y, 0);
with
    // alternate offset for each row
    float x = p[0] + 0.5 * ((int) y & 1);
roeland
Postby whersmy » Tue Apr 10, 2018 9:18 am
whersmy Tue Apr 10, 2018 9:18 am
Getting there! Is it possible to add a random rotation for the square planks/tiles? In practice you would only need 4 options, each 90 degrees turned. In order to get the right irregularity for now I solved it roughness.
whersmy
Postby smicha » Tue Apr 10, 2018 9:25 am
smicha Tue Apr 10, 2018 9:25 am
Share the scene please - great job.
smicha
Postby whersmy » Tue Apr 10, 2018 9:36 am
whersmy Tue Apr 10, 2018 9:36 am
Here we go. Usable for buildings as well if displacement is not necessary.
Tiles.orbx
(3.13 MiB) Downloaded 447 times
whersmy
Postby roeland » Wed Apr 11, 2018 4:44 am
roeland Wed Apr 11, 2018 4:44 am
Yes. The script as it is contains code to randomly rotate the texture by 180°:
    int flip = (rnd - floor(rnd)) < .5;
    // make UV mapping per cell and evaluate the right texture
    float plU = x - floor(x);
    float plV = y - floor(y);
    if (flip)
        plU = 1 - plU;
        plV = 1 - plV;
We can extend this code: for instance this randomly picks any of the 8 combinations of rotation (0°, 90°, 180°, 270°) and mirroring.
    int flip = (int) ((rnd - floor(rnd)) * 8);
    if (flip & 1)
        // flip U
        plU = 1 - plU;
    if (flip & 2)
        // flip V
        plV = 1 - plV;
    if (flip & 4)
        // flip over diagonal
        float tmp = plU;
        plU = plV;
        plV = tmp;
roeland
Postby Rik » Wed Apr 11, 2018 7:20 am
Rik Wed Apr 11, 2018 7:20 am
Hi Rowland
Can you tell us how we would use this in the plugins? I use max but have no idea about how to incorporate the code.
It look like it would be really useful.
Rik
PreviousNext
Return to Lua Scripting
Users browsing this forum: No registered users and 9 guests
Wed Apr 24, 2024 4:26 am [ UTC ]
