here is a simple Lua script to facilitate the MBB QUIXEL PBR material creation based on the great preset provided by miko3d here:
viewtopic.php?f=9&t=51470
I'm absolutely not an expert in QUIXEL, but I guess that the script could be useful to speedup the workflow.
The script searches and downloads the MBB_QUIXEL_PBR.orbx material provided by miko3d, asks for the albedo texture path, automatically imports all the needed maps in the proper pins, and then, the resulting material will be saved as an .orbx file if needed.
Note: you need to be connected to the internet, otherwise the script can't have access to the LiveDB
Here is the script:
If the script is opened in the Script Editor window, almost on top, it is possible to change some default values like the maps suffix that could be changed if you use a different pattern, or enabling/disabling the automatic saving of the ORBX material in the same folder of the Albedo texture. Then, if the script is saved, it can be execute directly from the script menu with the desired default values.
As always, comments, critics and feedbacks are more then welcome
ciao beppe
