Scripted graph animated mesh materials
PostPosted: Thu Aug 27, 2015 2:31 pm
by photonreality
We are working with quite big >40GB Alembic files and unfortunately Octane 2.xx fails to animate/refresh some of them properly.
So, I have tried to make a scripted node graph that loads geometry mesh from separate OBJ files and it works fine.
What I haven't been able to figure out so far is how to connect materials to this scripted graph.
Even a single material input would be very helpful as an example.
This is the first LUA script that I am working with and it seems that for some reason I can't access/copy the materials using self:getInputValue(inputs[4]).
I would appreciate it a lot if someone could help me to get the materials working in this script.
Alternatively there can be input mesh "guide" node that is connected to several materials so that we could copy/connect many materials.
Best Regards,
Hando
local AnimTexture = {}
local frameTime = 0
function getFrame(currentTime)
   return math.floor((currentTime + (frameTime / 2))/frameTime)
end
function AnimTexture.onInit(self, graph)
   graph:updateProperties({name = "Animated Mesh"})
  local inputInfos = {
     {type=octane.PT_STRING, label="File Name", defaultNodeType=octane.NT_FILE},
        {type=octane.PT_INT, label="Number of Digits", defaultNodeType=octane.NT_INT, defaultValue=3},
        {type=octane.PT_INT, label="Frames per Second", defaultNodeType=octane.NT_INT, defaultValue=30},
--        {type=octane.PT_MATERIAL, label="Material", defaultNodeType=octane.NT_IN_MATERIAL },
--        {type=octane.PT_GEOMETRY, label="Material Guide", defaultNodeType=octane.NT_GEO_MESH }
   local outputInfos = {
    {type=octane.PT_GEOMETRY, label="Animated Mesh"}
   inputs = graph:setInputLinkers(inputInfos)
   outputs = graph:setOutputLinkers(outputInfos)
   self:setEvaluateTimeChanges(true)
    mesh = octane.node.create{ type = octane.NT_GEO_MESH, name = "Anim Mesh", graphOwner=graph }
  outputs[1]:connectTo("input", mesh)
end
function AnimTexture.onEvaluate(self, graph)
  if self:timeWasChanged() then
     fileName = self:getInputValue(inputs[1])
   numDigits = self:getInputValue(inputs[2])
   sceneFps = self:getInputValue(inputs[3])
     frameTime = 1.0/sceneFps
     local frameNum = getFrame(graph.time)
     parentPath = octane.file.getParentDirectory(fileName)
     baseFile = octane.file.getFileNameWithoutExtension(fileName)
     fileExt = octane.file.getFileExtension(fileName)
     cleanFile = string.sub(baseFile, 1, baseFile:len() - numDigits)
   numFormat = "%0"..numDigits.."u"
   finalFile = octane.file.join(parentPath, cleanFile..string.format(numFormat, frameNum)..fileExt)
   mesh:setAttribute(octane.A_FILENAME, finalFile)
   mesh:setAttribute(octane.A_RELOAD, true)
   end
  return true
end
return AnimTexture
Re: Scripted graph animated mesh materials
PostPosted: Thu Aug 27, 2015 5:37 pm
by grimm
It's been awhile since I have looked at this stuff, but I have some things you could try. It looks like you are not passing the textures through the node, that is you need to also add them to the outputInfos table as well as the inputInfos table. Make sure that they are the right type. I'm not 100% sure this will work, but give it a try. :)
PostPosted: Fri Aug 28, 2015 6:29 am
by photonreality
Well, this script loads a new OBJ file (mesh) for each frame in the animation.
I have specified an input for a single material like this:
and I can connect a material to this input using Octane GUI.
Now I would like the script to connect this material specified by the input (4) the mesh loaded and I don't know how to do that correctly inside the scripted graph.
PostPosted: Mon Aug 31, 2015 9:09 am
by bepeg4d
I have added a couple of lines to your script, now it search for a material called "Mat" in the scene and connect it to the in_material input:
    local frameTime = 0
    end
            type            = octane.PT_MATERIAL,
            label           = "Material-in",
            fromNodeType    = octane.NT_IN_MATERIAL,
            fromPinId       = octane.P_INPUT
      sceneGraph = octane.project.getSceneGraph()
      Mater = octane.nodegraph.findItemsByName(sceneGraph, "Mat", false)
      inputs[4] : connectTo (octane.P_INPUT, Mater[1])
    end
       end
      return true
    end
    return AnimTexture
ciao beppe
