How do i connect a mesh material node to an outputmaterial
Forums: How do i connect a mesh material node to an outputmaterial
Forum for OctaneRender Lua scripting examples, discussion and support.
Postby Wallan » Thu Jul 02, 2015 9:41 pm
Wallan Thu Jul 02, 2015 9:41 pm
This must be really simple.
I just cant get it to work.
Could someone give me an example of how i connect a material in a mesh to a nt_out_material inside a graph.
I have created a graph that has some output materials named A,B,C etc.
Outside the Graph I have a mesh with materials with names A,B,C etc.
As the mesh has a couple of pins that not should be connected i have chosen to iterate the graph output materials and then find the mesh material pin with same name and connect them. Currently I get an error, cant connect node A with node A.
Windows 7 Ultimate 64bit 32Gb RAM. Intel Core i7-5820K [email protected] GHZ. Display uses a Gigabyte GTX 460 1Gb VRAM. Octane uses an EVGA GTX 970 4Gb VRAM.
Wallan
Re: How do i connect a mesh material node to an outputmaterial
Postby Wallan » Thu Jul 02, 2015 11:08 pm
Wallan Thu Jul 02, 2015 11:08 pm
Solved it myself in the end.
Could not figure out how to get the correct pin by name but iterating by index until i found the right ones solved my problems.
Wallan
Return to Lua Scripting
Who is online
Fri Jul 10, 2020 10:08 pm [ UTC ]
