Scripted node stuff
Forums: Scripted node stuff
Re: Scripted node stuff
Postby grimm » Sun Dec 07, 2014 11:31 pm
grimm Sun Dec 07, 2014 11:31 pm
stratified wrote:Hi Jason,
I think you're getting confused by the rounding errors:
****Event Started****
Scrubber Time - 0.03999999910593
I think this is frame # 0
The time in Octane is represented in floating point. For example if you have 25 fps, the frame duration is 0.04 seconds. In floating point this is represented as 0.03999... . If you then use math.floor(currentTime / frameTime), you will always underestimate the frame number. What you should do is have an epsilon and if you're close enough to the integer, clamp it to the integer. I know it's subtle but there's not much we can do here.
Yarg, fp errors are a pita! Thanks Thomas.
stratified wrote:It is operating in it's own graph. The turntable animation script takes a copy of the root graph of the project but not of the project itself. But octane.project.getSceneGraph() will always return the root graph of the original project. You can get around this by getting the parent graph of the scripted graph which is always the correct one.
Cool I will try that. :)
stratified wrote:Accessing the project settings is the culprit here. I guess the best thing is to always fetch them during evaluation.
cheers,
Thomas
I will move that too for now, thanks again.
Jason
Linux Mint 19 x64 | Nvidia GTX 980 4GB (displays) RTX 2070 8GB| Intel I7 5820K 3.8 Ghz | 32Gb Memory | Nvidia Driver 440.64
grimm
Postby grimm » Mon Dec 08, 2014 1:12 am
grimm Mon Dec 08, 2014 1:12 am
Hi Thomas,
I can get the parent of the graph easily by doing:
graph:getProperties().graphOwner
But for the life of me I can't get from there to getting the project properties so I can pull the number of frames per second?!?
I also modified my frame calculator function to this, works much better now: :D
function getFrame(currentTime)
   local halfFrame = frameTime/2 -- Force fix rounding errors
   return math.floor((currentTime + halfFrame)/frameTime)
end
grimm
Postby stratified » Mon Dec 08, 2014 1:40 am
stratified Mon Dec 08, 2014 1:40 am
I just tested it and I'm afraid you can't access the project settings either during evaluation until we fixed our bug. As a workaround I would add an extra input pin that configures the frame rate. It's a hassle for the user but I don't see any other way to work around this problem.
cheers,
Thomas
stratified
Postby grimm » Mon Dec 08, 2014 1:43 am
grimm Mon Dec 08, 2014 1:43 am
Cool, thanks, I will do that. :)
Jason
grimm
Postby grimm » Mon Dec 08, 2014 1:54 am
grimm Mon Dec 08, 2014 1:54 am
Hey Thomas,
*sigh* :| Looks like it's something else than accessing the root graph properties at start up. I removed all the properties code when I was adding the other input pin and it still locks up Octane when it is loading the script node script.
script_node_test2.ocs
(34.78 KiB) Downloaded 186 times
Thanks again,
Jason
grimm
Postby stratified » Mon Dec 08, 2014 2:06 am
stratified Mon Dec 08, 2014 2:06 am
Hey Jason,
I need to see your script that is referenced in the ocs (anim_texture.lua).
cheers,
Thomas
stratified
Postby grimm » Mon Dec 08, 2014 2:08 am
grimm Mon Dec 08, 2014 2:08 am
Here you go:
anim_texture.lua
(2.15 KiB) Downloaded 164 times
grimm
Postby stratified » Mon Dec 08, 2014 2:14 am
stratified Mon Dec 08, 2014 2:14 am
grimm wrote:Here you go:
anim_texture.lua
You can't access the project settings either. Line 28 needs to go. You should have the user configure the fps.
cheers,
Thomas
stratified
Postby grimm » Mon Dec 08, 2014 2:21 am
grimm Mon Dec 08, 2014 2:21 am
*AAARG!* Thanks Thomas,
The bad lines of code have been thoroughly exercised. :roll: And it's working.
Jason
grimm
Previous
Return to Lua Scripting
Thu Jul 02, 2020 8:28 am [ UTC ]
cron
