Camera Path Animation
Forums: Camera Path Animation
Forum for OctaneRender Lua scripting examples, discussion and support.
Re: Camera Path Animation
Postby MB » Sun Apr 27, 2014 12:12 am
MB Sun Apr 27, 2014 12:12 am
The need to be created in the modelling application, you will probabaly have to write a script for that too.
there is one posted on this thread for Rhino.
best
Windows 7 Enterprise, 2x Intel Xeon X5650 2.66 GHz, 24GB Ram, GTX 590, Quadro 5000, Quadro K4200
MB
Postby kavorka » Sun Apr 27, 2014 1:42 am
kavorka Sun Apr 27, 2014 1:42 am
Is there one for Blender by chance?
As of right now, I am trying to get my camera path out of Blender into the stand alone but the Alembic export/import somehow messes it up.
kavorka
Postby gmillas » Tue Apr 29, 2014 4:04 pm
gmillas Tue Apr 29, 2014 4:04 pm
I have create a plugin for rhino that uses curves and point int camera frames
it is posted above
gmillas
Postby MB » Wed Apr 30, 2014 9:41 am
MB Wed Apr 30, 2014 9:41 am
gmillas
Would it be possible for u to fix the path output to ffmpeg in your cool app to be able to handle file names and folder names with spaces in them, this would help a lot.
Thx
mark
MB
Postby gmillas » Wed Apr 30, 2014 4:10 pm
gmillas Wed Apr 30, 2014 4:10 pm
I 'll give a shot. I think its easy
8-)
gmillas
Postby MB » Tue May 13, 2014 6:55 pm
MB Tue May 13, 2014 6:55 pm
Did it turn out to be harder than you thought?
thx
MB
Postby BroAugustine » Wed May 14, 2014 2:00 pm
BroAugustine Wed May 14, 2014 2:00 pm
MB & gmillas,
Handling of space values for os.execute() is a bit tricky.
If you replace line 660 thru 671 in the latest script with the following, things should work.
Cheers
function ffmpeg()
    if OUT_PATH == nil then
        return 0
    end
    FORMAT=formatComboBox:getProperties().items[formatComboBox:getProperties().selectedIx]
    FPS=frameRateSlider:getProperties().value
    scriptDir = octane.file.getSpecialDirectories()["userScriptDirectory"]
    local octane_dir=[["]]..scriptDir.."\\ffmpeg.exe"..[["]]
    local ffmpeg_cmd = octane_dir .. " -i \"".. OUT_PATH .."\"".."%04d.png  -c:v libx264 -r ".. FPS .." -pix_fmt yuv420p ".."\"".. OUT_PATH .."." .. FORMAT.."\""
    local cmd = ffmpeg_cmd:gsub("\\",  "/")
    os.execute([["]]..cmd..[["]])
end
Win 7 64 | I7-2600K 3.7 GHz | GTX 460, GTX 760 / Driver 347.09 | Cuda 7.0.18
BroAugustine
Postby gmillas » Thu May 15, 2014 5:50 am
gmillas Thu May 15, 2014 5:50 am
Thanks for the addition
gmillas
Postby MB » Thu May 15, 2014 11:43 am
MB Thu May 15, 2014 11:43 am
Many many thanks :D
MB
Postby erges » Fri Jun 13, 2014 11:23 am
erges Fri Jun 13, 2014 11:23 am
Hi, Please, How to create the camera path in Maya? Is there the plugin or mel script?
erges
PreviousNext
Return to Lua Scripting
Who is online
Users browsing this forum: No registered users and 2 guests
Tue Dec 01, 2020 3:46 pm [ UTC ]
