Page 1 of 2
Camera mapping (1.30)
PostPosted: Tue Feb 11, 2014 4:53 am
by roeland
This script approximately maps a texture so it fits into the camera view. Note this does not take things like distortion and depth of field into account.
Updated for versions 2.26 and 3.01:
camera map.lua
(3.9 KiB) Downloaded 389 times
Additional features:
  • the script also works for orthographic and spherical cameras (for cylindrical cameras it's not possible to correctly map the texture).
  • You can camera map the environment texture by selecting the texture environment node (although it will look weird if you have reflections of the environment in your scene).
Note that
Roeland
Re: Camera mapping (1.30)
PostPosted: Mon Feb 17, 2014 1:01 pm
by r-username
love this script
Is there any way to repeat the script on a folder of png files so we can have camera/projection mapped animation? I think I can do this in the blender plugin but checking if there is an easy way to do this in the standalone.
cheers,
S
PostPosted: Wed Jan 14, 2015 8:12 am
by jitendra
roeland wrote:Since we changed the texture projections for version 1.30 I updated this script. The UV transform doesn't need the (.5, .5) offset anymore, and the width given for the scale is the full width, not the half width.
camera map 1.30.lua
Roeland
Thank you Roeland,
Works like a charm.
Best Regards, JITENDRA
PostPosted: Tue May 31, 2016 10:07 pm
by leehenshall
Great script! I can't seem to get it working with Octane 3.0. Can someone modify the script to make it compatible?
PostPosted: Thu Jun 02, 2016 10:13 pm
by roeland
The change to the resolution node in the render target broke quite some scripts.
When you get a complaint about a missing pin called octane.P_RESOLUTION, you can change:
local resolution = rendertarget:getPinValue(octane.P_RESOLUTION)
to:
local resolution = rendertarget:getInputNode(octane.P_FILM_SETTINGS):getPinValue(octane.P_RESOLUTION)
Roeland
PostPosted: Fri Jun 03, 2016 12:04 am
by calus
Thanks for the update an the Tip :)
PostPosted: Sat Jun 04, 2016 12:49 pm
by leehenshall
Thanks roeland.
I did a find and replace using notepad++ then restarted Octane and attempted to run the script with the image texture selected and still getting an error in Octane 3.
See attached image:
PostPosted: Sat Jun 04, 2016 12:59 pm
by leehenshall
Opps! sorry my mistake the fix does work. I just didn't have my render target selected/activated.
Thanks for the quick turn around roeland :)
PostPosted: Wed Jul 13, 2016 5:28 pm
by manalokos
The script is broken on V3.0, it cannot access P_RESOLUTION, and I don't know the syntax to fix it.
Can anyone help?
Kind regards
Filipe
PostPosted: Thu Jul 14, 2016 11:05 am
by bepeg4d
Hi Filipe,
could you try with this version?
camera_map_v3.lua
(3.97 KiB) Downloaded 479 times
ciao beppe
