Re: Get information from a mesh node?
Posted: Tue Jan 21, 2014 8:28 pm
If you go via the vertices, it gives you the same dimensions as the original OBJ file... So if you scale it, you have to recalculate the scaling yourself.
Community Forums for OTOY Customers
https://render.otoy.com/forum/
grimm wrote:Thanks Thomas, that's good to know. Here is my function if anyone is interested, any ideas to make it better will be greatly appreciated.
- Code: Select all
-- calculate the statistics of a mesh and return a table of those values
function getMeshStats(verts)
local meshStats = {}
local minX = 0
local maxX = 0
local minY = 0
local maxY = 0
local minZ = 0
local maxZ = 0
local lengthX = 0
local lengthY = 0
local lengthZ = 0
local x, y, z
-- find the bounding box
for k,v in pairs(verts) do
x = v[1]
if x > maxX then maxX = x end
if x < minX then minX = x end
y = v[2]
if y > maxY then maxY = y end
if y < minY then minY = y end
z = v[3]
if z > maxZ then maxZ = z end
if z < minZ then minZ = z end
end
meshStats["min_x"] = minX
meshStats["max_x"] = maxX
meshStats["min_y"] = minY
meshStats["max_y"] = maxY
meshStats["min_z"] = minZ
meshStats["max_z"] = maxZ
-- find the mesh's length for each axis
lengthX = maxX - minX
lengthY = maxY - minY
lengthZ = maxZ - minZ
meshStats["x_len"] = lengthX
meshStats["y_len"] = lengthY
meshStats["z_len"] = lengthZ
-- find the mesh's position
local posX = lengthX/2.0 + minX
local posY = lengthY/2.0 + minY
local posZ = lengthZ/2.0 + minZ
meshStats["pos_x"] = posX
meshStats["pos_y"] = posY
meshStats["pos_z"] = posZ
return meshStats
end
selectedMesh = octane.project.getSelection()[1]
verts = selectedMesh:getAttribute(octane.A_VERTICES)
meshStats = getMeshStats(verts)
print "X info"
print(meshStats["pos_x"])
print(meshStats["min_x"])
print(meshStats["max_x"])
print "Y info"
print(meshStats["pos_y"])
print(meshStats["min_y"])
print(meshStats["max_y"])
print "Z info"
print(meshStats["pos_z"])
print(meshStats["min_z"])
print(meshStats["max_z"])
If you do run the script, just make sure to select a mesh node first. Otherwise it will not work.
Jason
jitendra wrote:Hey Jason,
This script is still working well.
But can you help with converting this to a Scripted Nodegraph?
I want to use the output bounding box values in dynamically positioning other object (e.g. ground floor).
Happy to pay for the task as well.
Thanks.
