Creating your own image textures with the Octane Lua API
Posted: Mon Dec 09, 2013 5:00 am
Hi all,
In this example we'll explain how to create an image texture in Lua. At the end you should end up with a nice gradient texture. Let's have a look at (some of) the attributes of the image texture node (octane.NT_TEX_IMAGE):
What we need to do is correctly set up the A_BUFFER, A_SIZE and A_TYPE attributes of the image texture node. For our case we create an LDR_RGBA image which uses 4 bytes per pixel. First let's create a gradient image in Lua. The function createGradient will create an image "object" with a correct size, type and buffer. The function writes out a colour for each pixel. The colour is calculated by interpolating between the start and end colour with octane.vec.lerp. Every time we
encounter a new line in the image we recalculate the interpolation factor (it's a bit a waste of time to calculate the colour for each pixel but hey it's an example
Like always we start with a clean slate. We call createGradient to create a 500 by 500 pixels image with a red to yellow gradient:
Now that we have created an image, we use it to set up the image texture node. First we create the image texture node. Afterwards we use our image object to set up the A_BUFFER, A_SIZE and A_TYPE attributes of the node. Note the third false parameter of setAttribute, this means we don't immediately want to evaluate the node. Only after all attributes are set up correctly we call evaluate on the node:
If we would stop the script here we would have a correct image texture node but it's nice to have it on disk as well. We can do this by calling exportToFile on the node (We did this before in the geometry creation tutorial). All we have to do is specify a directory. Octane will create a subdirectory textures and create a file with the same name as our node (Octane uses .png for images of type LDR_RGBA and LDR_MONO. It uses .exr for images of type HDR_RGBA and HDR_MONO).
If all went well, you should have something like this:
have fun,
Thomas
- Code: Select all
A_BUFFER
• Description : Raw byte uncompressed data for the image.
• Type : AT_BYTE
• Array : true
A_SIZE
• Description : Size of the image in pixels.
• Type : AT_INT2
• Array : false
• Default Value : 0 0
A_TYPE
• Description : The image type, i.e. the data format used in A_BUFFER. Must be of type ImageType.
• Type : AT_INT
• Array : false
• Default Value : 0
- Code: Select all
-- Creates an LDR gradient image (4 bytes/pixel).
-- @param[in] x
-- horizontail size of the image
-- @param[in] y
-- vertical size of the image
-- @param[in] c1
-- start colour for the gradient.
-- @param[in] c2
-- end colour for the gradient.
-- @return
-- image buffer with a top to bottom gradient c1 > c2
local function createGradient(x, y, c1, c2)
-- create a data structure for the image
local image = {}
image.size = { x, y }
image.type = octane.image.type.LDR_RGBA
image.buffer = {}
-- fill in the buffer with a gradient
t = 0
for i = 1, x*y do
-- interpolate between start & end colour
local c = octane.vec.lerp(c2, c1, t)
table.insert(image.buffer, c[1])
table.insert(image.buffer, c[2])
table.insert(image.buffer, c[3])
table.insert(image.buffer, 255) -- alpha
-- on a new line, modify the interpolation factor
if (i % x == 0) then t = t + 1/y end
end
return image
end
- Code: Select all
-- start with a clean slate
octane.project.reset()
-- create a gradient (500x500, red -> yellow)
gradient = createGradient(500, 500, { 255, 0, 0 }, { 255, 255, 0 })
- Code: Select all
-- create an image texture node
texNode = octane.node.create{ type=octane.NT_TEX_IMAGE, name="Gradient Texture" }
-- set up the gradient in the attributes
texNode:setAttribute(octane.A_BUFFER , gradient.buffer , false)
texNode:setAttribute(octane.A_SIZE , gradient.size , false)
texNode:setAttribute(octane.A_TYPE , gradient.type , false)
-- evaluate the texture node
texNode:evaluate()
- Code: Select all
-- save out the image texture as a png
directory = "/tmp/lua"
-- this will export to "/tmp/lua/textures/Gradient Texture.png"
texNode:exportToFile(directory)
- Code: Select all
-- Roll our own image textures
-- @param[in] x
-- @param[in] y
-- @param[in] c1
-- @param[in] c2
-- @return
local image = {}
image.buffer = {}
t = 0
for i = 1, x*y do
end
return image
end
texNode:evaluate()
have fun,
Thomas
