Thank you Paul, I will give it a try.
Guillermo
I will do an Octane 3.08.3 build by the end of the week, which will hopefully fix your issue. Sorry for the delay.1 - For Autocad 2018 the plugin´s version is 3.7.0.22 (64 bit) that you uploaded , it is a different version from 2019 (3.08.1.23), but works fine.
2 - Yes works fine (Octane Standalone 3.08.3)
This looks like a bug in AutoCAD. acbr22.dbx mention in the error does not exist with AutoCAD 2019 - only for AutoCAD 2018. Can you pls send me a scene which produces this error?Now the 2019 plugin works fine (at least it loads); ACAD 2019 loads the plugin but it only render simple geometry, when you try to render more complex geometry it fails to load. In ACAD 2018 plugin load perfectly. I had attached some sample pics.
