ORBX.js Video Decoding Errors
Posted: Wed Nov 20, 2013 1:00 am
I think that orbx.js can become a very good product and we would use hundreds of instances
if it is possible to get it running smoothly. So i tested it a little.
On desktop PC (i7 Dual GTX680)
Only Google Chrome 33 Canary works reasonably well:
picture is displayed without artifacts and colors are correct if more than one connection is active.
On the first connection color levels are messes up, instead of 0..255 they are now 16..235.
This error appears only when a single connection is active.
Canary runs at only 32fps for some reason while CPU usage is 7%.
Chrome 31
It runs at 60fps, CPU usage is also somewhat higher.
But a lot of small white vertical and horizontal lines appear on the picture over time and they don't go away!
Almost like the famous hot pixels
Color levels are correct (if multiple connections are active).
UV colors are also correct.
On Notebook (i7 Intel HD Graphics 3000 & NVidia GT 540M)
All Chrome browsers (31, 32 Beta and 33 Canary) have the same issues:
Small white vertical and horizontal lines appear on the picture over time and they don't go away.
Also some nasty UV(?) color bleeding and shadows are visible constantly.
Color levels are sometimes correct (for example Chrome 32 beta is correct but 33 Canary is not).
Firefox browser crashes when Nvidia card is turned on and orbx.js runs.
Other browsers are unable to turn on Nvidia card even if explicitly requested and they don't crash
When Firefox is running on integrated Intel card it works the same way as Google Chrome, same artifacts,
color levels seem to be correct however.
Internet Explorer 10/11 displays video using only different intensity of green-blue color, no other colors.
(the same was Galaxy Note 3 using Chrome for Android). Is is using h264 codec?
After running the instance for few hours, quality drops to 1%..30% (QOS1,2) on all new connections, initially it was 100% (QOS4,5).
At the same time speedtest.net repots 100Mbps speed on client computers and 350Mbps on AWS instance.
Pathping shows 0% packet loss...
And after few moments orbx.js is no longer able to connect to the instance at all.
Remote desktop connection works still fine and rebooting the instance is the only thing that helps.
Best Regards,
Hando
Chrome 31
Best Regards,
Hando
