Hello World: OctaneRender 4 is here
Forums: Hello World: OctaneRender 4 is here
Re: Hello World: OctaneRender 4 is here
Postby evilkoolade » Wed Apr 18, 2018 12:41 am
evilkoolade Wed Apr 18, 2018 12:41 am
Any chance Carrara will be added to the subscription model?
evilkoolade
Postby drmaddogs2 » Thu Apr 19, 2018 10:58 am
drmaddogs2 Thu Apr 19, 2018 10:58 am
'Scene processing and load speed has been incredibly improved. You probably missed that due logic of standalone. Also AI denoiser is another weapon'
for these reasons I'm looking at using the Standalone a great deal more.. it simply wasn't the case where before, time seemed better utilized just using the plug(I use C4d) to get work done.. which brings me to the question of what might a 'updated plug for C4d might entail where 'Scene processing and load speed is involved' as the ver 4 plug rolls out. I imagine the Standalone and format delivers a lot of the improvements in Standalone speed.. I wonder if that can be accomplished inside the C4d environ.. if at all?
drmaddogs2
Postby Konni » Thu Apr 19, 2018 2:54 pm
Konni Thu Apr 19, 2018 2:54 pm
Hi all,
I'm a new user in 3D and render world.
As new user I don't have Octane standalone v2 nor v3. What I have now just a single GTX 1070 and Win 10.
So my question is: Can I download standalone V4 and use for personal use for FREE without any monthly subscriptions/fees?
Is that correct?
Thank you for your answers
Konni
Postby Uhlhorn » Thu Apr 26, 2018 9:23 pm
Uhlhorn Thu Apr 26, 2018 9:23 pm
I found two bugs:
  • When denoising larger renderings the denoise screen is black.
  • Loading of render a state is not possible.
Uhlhorn
Postby haze » Fri Apr 27, 2018 3:19 am
haze Fri Apr 27, 2018 3:19 am
Uhlhorn wrote:I found two bugs:
Thanks, we are still optimising VRAM usage by the denoiser, but that is likely the reason that it fails to denoise your image currently. You could try to experiment with out of core geometry to save some more VRAM for the denoiser to use.
Render states should be loading, if saved by the same build. We'll look into it.
haze
Postby haze » Fri Apr 27, 2018 3:30 am
haze Fri Apr 27, 2018 3:30 am
drmaddogs2 wrote:'Scene processing and load speed has been incredibly improved. You probably missed that due logic of standalone. Also AI denoiser is another weapon'
We are looking to reach a point where we can start to release "test" builds, and then development plugin builds could be released.
You should see the same performance improvements in the plugin, as you see in standalone.
haze
Postby Uhlhorn » Fri Apr 27, 2018 4:22 pm
Uhlhorn Fri Apr 27, 2018 4:22 pm
haze wrote:You could try to experiment with out of core geometry to save some more VRAM for the denoiser to use.
Out of core geometry does not solve the problem.
haze wrote:Render states should be loading, if saved by the same build. We'll look into it.
On large renderings I save the render state all couple of hours. So it is definitely the same build. But it is not working.
Uhlhorn
Postby philippebeau » Wed May 02, 2018 7:00 am
philippebeau Wed May 02, 2018 7:00 am
For the problem with the denoiser and the black screen, I have the same problem but if I use a single GPU by activating suelo deny without tonemapping and rendering in the preferences it works
Best regard
Philippe BEAU
philippebeau
Postby ramone163 » Wed May 02, 2018 8:29 am
ramone163 Wed May 02, 2018 8:29 am
Batch RenderJob node doesn't work. Hit RUN and nothing happens.
Batch Rendering from scripts:
1) missing render priority option
2) if I try to render 2 or 3 Targets, render images are black or cut or with artifacts. When rendering only 1 target - everything is OK. Please fix this.
And maybe it is time for XB2?
Urbach says that new versions will be more often. But it is 1.5 months from XB1. Often? Now it is same as always. With this speed, we will get XB3 at the end of the year, and plugins in the next year.
GPU: 980+1080+1080Ti; 3ds max;
Behance portfolio; Handmadefont.com;
ramone163
Postby Uhlhorn » Wed May 02, 2018 2:52 pm
Uhlhorn Wed May 02, 2018 2:52 pm
I found an other bug:
When using transparency in Octane 4 it is not working. But the same file works fine in Octane 3.
Uhlhorn
PreviousNext
Return to News & Announcements
Who is online
Users browsing this forum: No registered users and 21 guests
Fri Apr 19, 2024 12:30 pm [ UTC ]
