Page 1 of 7
ORBX.js and Octane Cloud - in the Amazon Marketplace!
PostPosted: Tue Nov 05, 2013 9:01 am
by Goldorak
OTOY technology is powering the new G2 GPUs launching today on Amazon EC2 for Windows and Linux.
This is a support and technical Q & A forum for the OTOY Amazon Machine Images.
https://aws.amazon.com/marketplace/sear ... Terms=otoy
Re: ORBX.js and Octane Cloud - in the Amazon Marketplace!
PostPosted: Tue Nov 05, 2013 10:28 pm
by whersmy
Wow yes! So much win!
I definitely like where this is going :o
PostPosted: Tue Nov 05, 2013 10:31 pm
by grimm
So does this mean that, for instance with the Blender plugin, we point the plugin to an Amazon G2 IP to use one?
PostPosted: Tue Nov 05, 2013 11:01 pm
by JNDesign
No support for Revit plugin in Australia.
PostPosted: Tue Nov 05, 2013 11:09 pm
by Goldorak
Yes - since the Blender plug-in is IP based, it could work.
Without much effort, you can also run Blender (or any other Windows/Linux) app on the OTOY G2 cloud server directly, and eventually plug-ins included. For this launch, we've re already re-factored Octane SA to boot up automatically inside the AMIs without an individual license - it is usage based. This is something we will do for plug-ins next. With Autodesk applications working inside the Octane AMI, it is technically possible to get usage based plug-ins for Max, Maya, Revit and Inventor up and running.
For users who are not AWS devs, we are setting up the Octane Cloud service (which is built on the same AMIs in the marketplace). It includes fully licensed version of Windows and a turn key service for remote workstation based around the Octane Render pipeline.
PostPosted: Tue Nov 05, 2013 11:56 pm
by grimm
Thanks Goldorak! :) Sounds like fun. I'm assuming that eventually you will be able to add more GPU's to the mix?
PostPosted: Wed Nov 06, 2013 2:00 am
by Goldorak
Yes - we're starting with one GPU per instance today, but the whole point of Octane Render Cloud Edition is to use as many GPUs as you want when they are available. The work we did earlier this year which can connect hundreds of GPUs for a single render will be put to use for this.
PostPosted: Wed Nov 06, 2013 2:30 am
by p3taoctane
Now we are starting to cook like hot chocolate : > )
PostPosted: Wed Nov 06, 2013 10:48 am
by thenomad
Is it possible to render on multiple nodes simultaneously at the moment, or is that coming soon? If it is, I think I might be spinning up 10 or so instances today for a test...
Also, I've been doing some research, and it looks like the G2 nodes are about 4/5 of the speed of a GEForce 770 - is that about accurate?
Very excited by this.
PostPosted: Wed Nov 06, 2013 11:36 am
by glimpse
thenomad wrote: it looks like the G2 nodes are about 4/5 of the speed of a GEForce 770 - is that about accurate?
I might be wrong but I believe they are using k10 inside =)
"G2 instances provide access to NVIDIA GRID GPUs (“Kepler” GK104) each with 1,536 CUDA cores and 4GB of video memory"
(SOURCE: http://aws.amazon.com/ec2/instance-types/)
