OctaneRender 4 for Revit [OBSOLETE]
Posted: Wed Nov 21, 2018 1:04 am
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Revit - TEST and STABLE releases.
IMPORTANT: If you get an "Exception starting render : System.MissingMethodException..." error when opening the Viewport with Revit 2018, install the Revit 2018.1 (or later) update.
Revit Version
This version runs on Revit 2017, 2018.1 and 2019 on Windows Vista, Windows 7, Windows 8 and Windows 10, 64 bit.
License upgrade
Unless you have a subscription license, you will have to upgrade your version 3 licenses to version 4. This upgrade is free and can be done via these 4 steps:
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 387 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
Network Rendering
For Network Rendering, you must use the Octane slave release from the Octane Standalone installer which matches the exact Octane version of the plugin you are using. This version matches OctaneRender Standalone 4.00.
Support Issues
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Nvidia driver version
- Revit version and build number (Help -> About Revit -> Build Number)
- OctaneRender for Revit version (ie. 1.02a)
- If relevant - supply the Journal file for the Revit session where the support issue occurred. Journal files can be found in C:\Users\[username]\AppData\Local\Autodesk\Revit\Autodesk Revit [Revit version]\Journals
For more information
- Check the specific Octane 2.0 features in this plugin at http://render.otoy.com/manuals/Revit/?page_id=536
- Read the on-line manual
- Read the FAQ
- Post your question on this forum thread
Download Links
Current STABLE build (Octane 4.01.1)
Previous STABLE build (Octane 4.01.1)
Release History
4.02.1.60 (12-Apr-2019)
- Resolved issues with materials not rendering correctly or being editable introduced in 4.02.1.58
4.02.1.58 (19-Feb-2019)
- Compiled with Octane 4.02.1
4.01.1.57 (12-Dec-2018)
- Compiled with Octane 4.01.1
- Fixed issue where opening the plugin whilst viewing a 3d view would cause the materials to be reset to their default
4.00.0.57 (01-Dec-2018)
- Fixed bug where the Denoise Beauty pass could not be selected from the render passes combo box on the Viewport toolbar
- When you Viewport Navigation mode, the camera position and target pins can now be edited
4.00.0.56 (22-Nov-2018)
- Compiled with Octane 4.00. (To learn more about the new features and improvements of OctaneRender 4, please check out our blog post.)
- Changed Devices tab to use the Octane API panel
- Added Denoiser options in the Imager settings
- Added Denoised Beauty pass to the Select Render Pass combobox on the Viewport toolbar
- Added Kernel AI Light options
- Added RenderPasses Denoiser passes
Revit Version
License upgrade
- Go to https://home.otoy.com/render/octane-render/purchase/
- Select "Upgrade" in the top menu.
- Click on "UPGRADE NOW" next to "Upgrade existing licenses to OctaneRender 4".
- Select the licenses you want to upgrade and confirm.
Network Rendering
Support Issues
- 32 or 64 bit
- Amount of RAM
- Read the FAQ
Download Links
- For users with a Regular license
- - Revit 2019 - OctaneRender for Revit 2019 4.02.1.60
- Revit 2018 - OctaneRender for Revit 2018 4.02.1.60
- Revit 2017 - OctaneRender for Revit 2017 4.02.1.60
For users with a Studio subscription license
- - Revit 2019 - Out of date - use the Octane 2018 version
- Revit 2018 - Out of date - use the Octane 2018 version
- Revit 2017 - Out of date - use the Octane 2018 version
Demo version
- - Revit 2019 - OctaneRender for Revit 2019 4.01.1.57
- Revit 2018 - OctaneRender for Revit 2018 4.01.1.57
- Revit 2017 - OctaneRender for Revit 2017 4.01.1.57
Demo version
Release History
