Render won't start
Forums: Render won't start
Autodesk Revit (Integrated Plugin developed by Paul Kinnane)
Render won't start
Postby timbarnes » Mon May 22, 2017 7:11 pm
timbarnes Mon May 22, 2017 7:11 pm
I'm using the latest Octane (downloaded today), with Revit 2017, and receive the following message when trying to start a render:
Exception starting render : System.NullReferenceException: Object reference not set to an instance of an object.
at OctaneRenderPlugin.CameraChangeMonitor..UpdateValues(View3D view)
at OctaneRenderPlugin.CameraChangeMonitor..ctor()
at OctaneRenderPlugin.RenderManager.CreateCameraMonitor()
at OctaneRenderPlugin.RenderManager.StartRender()
Octane Release number is 3.6.5.46
Revit Release number is 17.0.1128.0 / 20170419_0315(x64) / 2017.2.1.
I'm also seeing a TimerTickEvent error (see attachment) when Octane starts rendering. If this error occurs, Revit crashes.
Any idea what's going on?
tim
Mac Pro 3,1 / Lion / 14G RAM / ATI HD 2600 / nVidia GTX 470
i5-750 / Windows 7 Pro 64bit / 8G RAM / Quadro FX 580
Revit 2011, SketchUp 8, Rhino
timbarnes
Re: Render won't start
Postby face_off » Tue May 23, 2017 1:14 am
face_off Tue May 23, 2017 1:14 am
Hi - is this problem happening on all scenes, or just one? What was the previous version you had installed?
Postby timbarnes » Tue May 23, 2017 2:24 am
timbarnes Tue May 23, 2017 2:24 am
It happens on multiple scenes, but so far only in this one file. I think I have been using the same (most recent) version for a while - I just updated it today because of the error, in the hope that it was a configuration problem of some kind. I was not able to get any of the views I tried today to render from this file.
I'll try to do some experiments tomorrow to see if there is some kind of pattern. I have done an audit on the Revit file: no errors were reported by the audit, but the Octane problem persists.
Regards,
tim
timbarnes
Postby face_off » Tue May 23, 2017 11:53 am
face_off Tue May 23, 2017 11:53 am
Would it be possible to send me the .rvt file pls? I need to determine if it's a specific issue with that file, or a general bug that has been introduced to the plugin. Those errors are indicating there is a problem with the Revit Camera/View.
Postby timbarnes » Tue May 23, 2017 4:56 pm
timbarnes Tue May 23, 2017 4:56 pm
I sent a PM with a link to the file. Let me know if you have any trouble accessing it.
Tim
timbarnes
Postby face_off » Sun May 28, 2017 12:27 pm
face_off Sun May 28, 2017 12:27 pm
I have investigated this issue, and it is a corrupted Revit View or sun settings. About 50% of the time, even without Octane loaded, just selected the views which cause this error will lock up Revit. So there are issues with those Views, and they should be recreated. I have added some checking in the next release of the plugin which will notify you of this problem.
Postby timbarnes » Sun May 28, 2017 6:33 pm
timbarnes Sun May 28, 2017 6:33 pm
Thanks - I came to the same conclusion, as I discovered the views won't render using Autodesk's cloud renderer either.
Regards,
Tim
timbarnes
Return to Autodesk Revit
Tue Apr 16, 2024 8:52 pm [ UTC ]
