Re: 2.10 Texture Problems
Posted: Tue Sep 30, 2014 9:40 pm
Sorry Paul - I was using version 2014_2_10_0_12
Ed, did you CREATE that scene with release 2.10.0.12 of the plugin installed?I also tried the latest version with a simple model of a chair and had a similar result. Since it's small, it may help isolate the issue.
I think what has happened is that the "Import Material from ORBX" feature has caused a situation where texturemap files were being loaded incorrectly in some situations, and that "blanked" out the image filename in the Octane material - which was then saved to the rvt file. So you will need to "Reconvert from Revit" to get everything relinked. However there is another issue I am correcting at the moment which is causing the popping of the "Cannot connect node...." message that Ed is getting with the chair. I think that error is caused when potentially moving assets between Revit scenes and the material identifier that Revit uses is changed.All seems to be working well now however the specified material still doesnt come thru when I first open octane window.
I have to select the floor for example and the "reconvert from Revit" like you said.
These materials are from Revit
otherwise works like acharm.
Also, what is the "Beauty" Button for?
Is it possible you default materials have invalid texturemap folders? If you Reconvert, then save the rvt, I assume you do not need to Reconvert the scene again?I still have to reconvert from Revit to get materials.
Standard Revit materials.
