Forums: World Machine - First Renders
djropi
- Licensed Customer
by djropi » Mon Dec 28, 2015 10:44 pm
djropi
Pt. 1500 samples.
- Attachments
djropi
- Licensed Customer
by Yambo » Tue Dec 29, 2015 9:47 am
Yambo
Great work!
How do you transfer your maps and geometry from World Machine? There are few approaches and i didn't found what works the best for me:
1. Export height map used as displacement map on a plane in octane + bitmap textures for texturing in octane
2. Export high res mesh from World Machine and only texture it in octane
3. export low poly mesh and normal map
etc...
what approach are you using?
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build:
http://goo.gl/hYp8e0 https://yambo.me
Yambo
- Licensed Customer
by djropi » Tue Dec 29, 2015 6:49 pm
djropi
Hi Yambo,
Thanks! The first method you listed of exporting a displacement map and using a plane is my main approach. I'll put a turbosmooth modifier on the plane and increase the iterations as needed (7 - 8) to increase the resolution. The textures I export as a 16 bit .png and they can be applied as a diffuse texture for a glossy material. Making sure the bitmaps have the proper information (flow maps and such) from WM is the key. Normal maps are also something you can export from WM in the converter tab which helps to add some extra detail. Takes a few tries to remember the process, but I used this tutorial a few times if I forgot anything:
https://www.youtube.com/watch?v=9IBZjkxgpq8Hope this helps! Looking forward to seeing your work.
djropi
- Licensed Customer
by Yambo » Tue Dec 29, 2015 9:09 pm
Yambo
Cheers man!
Thank you.
Yambo
- Licensed Customer
Return to Works In Progress
Who is online
Users browsing this forum: No registered users and 19 guests
