Paper (money)
Forums: Paper (money)
Re: Paper (money)
Postby shishkovdima » Tue May 31, 2016 4:42 pm
shishkovdima Tue May 31, 2016 4:42 pm
itsallgoode9 wrote:In terms of the translucence, it's looking pretty good but I think you're missing the look of fibers/surface bump in the paper (not wrinkles or creases, actual tooth of the paper), in both the dollar bill and the register receipt. I've been working with matte paper renders alot lately and it helps to scan in a blank piece of black or grey paper and use that as source material to create a subtle roughness and bump. it might be good to experiment with using that for translucence in your tests too.
Thank you for the feedback :) Of course, using a high resolution scan will add a lot more details, I can't agree more. The thing is I was just experimenting to get that translucent look and wasn't that much worried about everything else. As you can see in the setup, I didn't even add reflectivity to the parts of paper coverd with ink. But I think that you will agree, that even using some (not so HQ photos) of money found on the internet, produces amazing results in terms of paper surface :) . Here is a close-up shot:
I think I even could increase the bump strength a bit more for it to be more pronounced. But of course if it was a commercial project where paper is in focus, you would add as much detail as possible.
Have a nice day :D
http://dimashishkov.tumblr.com/
Windows 7 Professional | Cinema4D R16.050 | Octane 2.25 | i7 4790K | 16GB RAM | EVGA GTX 980Ti 6Gb
shishkovdima
Re: Paper (money)
Postby aoktar » Tue May 31, 2016 4:45 pm
aoktar Tue May 31, 2016 4:45 pm
I loved that too much. It's a great setup and render.
Re: Paper (money)
Postby shishkovdima » Tue May 31, 2016 5:07 pm
shishkovdima Tue May 31, 2016 5:07 pm
aoktar wrote:I loved that too much. It's a great setup and render.
Thank you very much! Glad you like it :D
shishkovdima
Re: Paper (money)
Postby Marvez » Tue May 31, 2016 6:18 pm
Marvez Tue May 31, 2016 6:18 pm
very nice work
how do you handle the security strip in vintage (2012-2014) of printed money and new ?
I7 5820K 16MB RAM SSD850PRO GTX 970/780
Marvez
Re: Paper (money)
Postby shishkovdima » Tue May 31, 2016 6:58 pm
shishkovdima Tue May 31, 2016 6:58 pm
Marvez wrote:very nice work
I would go the same way: just add another mix node and mix a strip texture with the current mixes. Just make sure to use it only for the transmission. I suppose it should be completely invisible in diffuse channel. At least judging from the second image. As for the first one, I would create a new material separetely for the strip (maybe make it glossy with some colourful gradient in the specular channel) and use a mix material to mix my current material with the strip material and used a B&W mask as amount.
To be honest I haven't seen the new banknotes in real life, so it is pretty hard to judge how it really interacts with light.
shishkovdima
Re: Paper (money)
Postby blackshore » Sun Jul 03, 2016 4:29 pm
blackshore Sun Jul 03, 2016 4:29 pm
Wow, Great work! Thanks for the Shader overview aswell!
blackshore
Re: Paper (money)
Postby shishkovdima » Wed Jul 06, 2016 12:49 pm
shishkovdima Wed Jul 06, 2016 12:49 pm
blackshore wrote:Wow, Great work! Thanks for the Shader overview aswell!
Thank you. Glad that it may be helpful for someone.
shishkovdima
Re: Paper (money)
Postby digitalcompositing » Thu Apr 27, 2017 4:24 pm
digitalcompositing Thu Apr 27, 2017 4:24 pm
Wow! I lke the approach. Does anyone have an idea how to apply a similar effect to a "thick" Polygon or for example to a box? Right now it only works on single polygons with no thicknes .. right?
I would be glad if someone had an idea.
digitalcompositing
Re: Paper (money)
Postby slyblake » Mon Jun 18, 2018 5:13 am
slyblake Mon Jun 18, 2018 5:13 am
hi do u have a similar setup making normal white paper look as good as yours? really need help as this is my first time using octane! thankss
slyblake
Previous
Return to Works In Progress
Mon Feb 18, 2019 9:50 am [ UTC ]
