Report on all Materials
Forums: Report on all Materials
Graphisoft ArchiCAD (Integrated Plugin developed by Paul Kinnane)
Postby s3d-weyrauch » Mon Jan 23, 2017 1:13 pm
s3d-weyrauch Mon Jan 23, 2017 1:13 pm
our office works with an own ArchiCAD template, and I have prepared all of the materials in Octane.
We should reorganize our server, and we had to move the textures as well (it was not my decision...). Anyway, I have to check sometimes all of the loaded textures, I would like to avoid invalid paths (old servers, user folders, etc.).
Is there any possibility to get a list from any loaded materials, that contains the path of the texture?
It would be interessant about used proxies as well...
Thank You
David
BIM team leader
Win 10 | ArchiCAD GER 23-24 | Octane Plugin for ArchiCAD
13 Licenses | Network Render over 12 graphic cards
s3d-weyrauch
Re: Report on all Materials
Postby face_off » Wed Jan 25, 2017 6:39 am
face_off Wed Jan 25, 2017 6:39 am
I suspect this would not be easy to implement, but I am doing some work on the ArchiCAD plugin over the next couple of days, so I will take a closer look.
Postby s3d-weyrauch » Tue Feb 14, 2017 3:57 pm
s3d-weyrauch Tue Feb 14, 2017 3:57 pm
Thank Paul. I have tested the latest plugin, and the result doesn't show the list of the files with path.
Do I something wrong?
David
BIM team leader
s3d-weyrauch
Postby face_off » Tue Feb 14, 2017 9:27 pm
face_off Tue Feb 14, 2017 9:27 pm
Hi David - are you certain there are images in your materials? Or if the png/jpg files are missing, they will not be reported as missing either (since the image filename will be blank in the Image node).
Postby s3d-weyrauch » Thu Feb 16, 2017 9:33 am
s3d-weyrauch Thu Feb 16, 2017 9:33 am
Not missing, not a proxy... :( How can I serve you more info about this issue?
David
BIM team leader
s3d-weyrauch
Postby face_off » Fri Feb 17, 2017 7:49 am
face_off Fri Feb 17, 2017 7:49 am
I will investigate the problem when doing the 3.06 release (probably late next week).
Return to Graphisoft ArchiCAD
Users browsing this forum: No registered users and 5 guests
Fri Apr 19, 2024 1:33 pm [ UTC ]
