Page 17 of 21
Re: OctaneRender 3 for ArchiCAD [TEST and STABLE]
Posted:
Mon Mar 19, 2018 10:16 pm
by Daniel_Ward
Hi Paul,
I'm sure you've got your hands full with other things, but I've found that the current plug-in build crashes ArchiCAD trying to activate. It's fine if the licence is already active on the PC, but if it need to acquire an available licence, ArchiCAD crashes to desktop.
The only way I can activate Octane for ArchiCAD at the moment is to have one of my older ArchiCAD's (v19 in this case) still on 3.07, so I can use that build to acquire the licence, then switch to AC20 or 21 on the 3.08 build and it doesn't then have any issues because the licence is already active on my PC.
Hope this makes sense?
Cheers, Dan.
Posted:
Mon Mar 19, 2018 10:53 pm
by face_off
This is fixed in the next Octane build (RC2). I will post a plugin installer for it today.
Posted:
Tue Mar 20, 2018 1:51 am
by face_off
I have updated the TEST build installers at the top of this thread with:
3.8.0.81
- Compiled with Octane 3.08 RC2
This should resolve the crash when trying to authenticate.
Posted:
Tue Mar 20, 2018 8:51 am
by Jasonr
Hi Paul.
For the first time I get this error:
This happened after I applied a texture with displacement channel and checked "Follow smoothed Normal"
Suddenly octane freezes with really slow reaction.
Any clue??
thank you
CUDA error 702 on device 2: the launch timed out and was terminated
-> kernel execution failed(report)
-> failed to launch kernel(ptBrdf2)
device 2: direct light kernel failed
CUDA error 702 on device 0: the launch timed out and was terminated
device 0: direct light kernel failed
-> failed to unregister pinned memory
-> could not get memory info
-> failed to deallocate device memory
device 2: failed to upload data texture 4 of context 0
device 0: failed to upload data texture 4 of context 0
Posted:
Tue Mar 20, 2018 9:19 am
by Jasonr
I tried with a different texture with displacement channel at the same model and I get this error:
CUDA error 719 on device 0: unspecified launch failure
CUDA error 719 on device 2: unspecified launch failure
-> failed to copy memory to device.
-> failed to launch kernel(init3)
After that Octane freezes.
This happens when I set the follow smoothed normal
Posted:
Tue Mar 20, 2018 9:47 am
by face_off
Any clue??
Are you using the latest version? If you save to ORBX and load into Octane Standalone, do you get the same error?
Posted:
Tue Mar 20, 2018 11:01 am
by rappet
Jasonr wrote:Hi Paul.
Any clue??
thank you
Hi Jason,
Seems you have no problem on device 1... are you rendering with your two titans and your quador or only with your two titans (and not with device 1)?
greetz?
Posted:
Tue Mar 20, 2018 12:05 pm
by Jasonr
I am using only the two Titans.
I made a test with standalone I got the same results.
Octane freezed and the info text became red with "all failed" message.
I tried with a simple archicad file of just two walls, enabled the smoot option normal and again octane freezes with the following error message:
Started logging on 20.03.18 13:57:48
OctaneRender 3.08 RC 2 (3080011)
Could not load 'I:\GRAPHISOFT\ARCHICAD 21\ARCHICAD Library 21\Electrical\Электроблок 16—21.lcf\1.6 AC16—21\3D\Textures\AluminiumBrushed.jpg:rgba'.
Could not load 'I:\GRAPHISOFT\ARCHICAD 21\ARCHICAD Library 21\Electrical\Электроблок 16—21.lcf\1.6 AC16—21\3D\Textures\gf_LightWhite.bmp:rgba'.
-> failed to load symbol data to the device(deep_data)
device 2: failed to upload the deep params
device 0: failed to upload the deep params
Posted:
Wed Mar 21, 2018 2:11 am
by face_off
As indicated above, you need to export to ORBX and see if you get the same error in Octane Standalone 3.08 RC2.
Posted:
Wed Mar 21, 2018 2:17 pm
by Jasonr
Hi Paul.
I have tested it already and it seems that the problem persists.
I cannot find the log in the standalone to upload the error.
