OctaneRender 3 for ArchiCAD [OBSOLETE]
Forums: OctaneRender 3 for ArchiCAD [OBSOLETE]
Graphisoft ArchiCAD (Integrated Plugin developed by Paul Kinnane)
Re: OctaneRender 3 for ArchiCAD [TEST and STABLE]
Postby Daniel_Ward » Mon Mar 19, 2018 10:16 pm
Daniel_Ward Mon Mar 19, 2018 10:16 pm
Hi Paul,
I'm sure you've got your hands full with other things, but I've found that the current plug-in build crashes ArchiCAD trying to activate. It's fine if the licence is already active on the PC, but if it need to acquire an available licence, ArchiCAD crashes to desktop.
The only way I can activate Octane for ArchiCAD at the moment is to have one of my older ArchiCAD's (v19 in this case) still on 3.07, so I can use that build to acquire the licence, then switch to AC20 or 21 on the 3.08 build and it doesn't then have any issues because the licence is already active on my PC.
Hope this makes sense?
Cheers, Dan.
+MAP Architects, Christchurch - New Zealand
ArchiCAD 4.12 - ArchiCAD 24 || Octane for ArchiCAD
i7-7700K - Gigabyte Aorus Z270X Gaming 9 - 32Gb RAM - 3x Gigibyte GTX1070 G1 Gaming - Window 10 64Bit
Daniel_Ward
Postby face_off » Mon Mar 19, 2018 10:53 pm
face_off Mon Mar 19, 2018 10:53 pm
This is fixed in the next Octane build (RC2). I will post a plugin installer for it today.
Postby face_off » Tue Mar 20, 2018 1:51 am
face_off Tue Mar 20, 2018 1:51 am
I have updated the TEST build installers at the top of this thread with:
3.8.0.81
- Compiled with Octane 3.08 RC2
This should resolve the crash when trying to authenticate.
Postby Jasonr » Tue Mar 20, 2018 8:51 am
Jasonr Tue Mar 20, 2018 8:51 am
Hi Paul.
For the first time I get this error:
This happened after I applied a texture with displacement channel and checked "Follow smoothed Normal"
Suddenly octane freezes with really slow reaction.
Any clue??
thank you
CUDA error 702 on device 2: the launch timed out and was terminated
-> kernel execution failed(report)
-> failed to launch kernel(ptBrdf2)
device 2: direct light kernel failed
CUDA error 702 on device 0: the launch timed out and was terminated
device 0: direct light kernel failed
-> failed to unregister pinned memory
-> could not get memory info
-> failed to deallocate device memory
device 2: failed to upload data texture 4 of context 0
device 0: failed to upload data texture 4 of context 0
ASUS Z10 PE-D8 WS/2 x XEON E5-2680 V4/64GB RAM/1xQuadro M5000/2x NVIDIA GTX TITAN Pascal/ Windows 10/ Archicad 20
Jasonr
Postby Jasonr » Tue Mar 20, 2018 9:19 am
Jasonr Tue Mar 20, 2018 9:19 am
I tried with a different texture with displacement channel at the same model and I get this error:
CUDA error 719 on device 0: unspecified launch failure
CUDA error 719 on device 2: unspecified launch failure
-> failed to copy memory to device.
-> failed to launch kernel(init3)
After that Octane freezes.
This happens when I set the follow smoothed normal
Jasonr
Postby face_off » Tue Mar 20, 2018 9:47 am
face_off Tue Mar 20, 2018 9:47 am
Any clue??
Are you using the latest version? If you save to ORBX and load into Octane Standalone, do you get the same error?
Postby rappet » Tue Mar 20, 2018 11:01 am
rappet Tue Mar 20, 2018 11:01 am
Jasonr wrote:Hi Paul.
Any clue??
thank you
Hi Jason,
Seems you have no problem on device 1... are you rendering with your two titans and your quador or only with your two titans (and not with device 1)?
greetz?
rappet
Postby Jasonr » Tue Mar 20, 2018 12:05 pm
Jasonr Tue Mar 20, 2018 12:05 pm
I am using only the two Titans.
I made a test with standalone I got the same results.
Octane freezed and the info text became red with "all failed" message.
I tried with a simple archicad file of just two walls, enabled the smoot option normal and again octane freezes with the following error message:
Started logging on 20.03.18 13:57:48
OctaneRender 3.08 RC 2 (3080011)
Could not load 'I:\GRAPHISOFT\ARCHICAD 21\ARCHICAD Library 21\Electrical\Электроблок 16—21.lcf\1.6 AC16—21\3D\Textures\AluminiumBrushed.jpg:rgba'.
Could not load 'I:\GRAPHISOFT\ARCHICAD 21\ARCHICAD Library 21\Electrical\Электроблок 16—21.lcf\1.6 AC16—21\3D\Textures\gf_LightWhite.bmp:rgba'.
-> failed to load symbol data to the device(deep_data)
device 2: failed to upload the deep params
device 0: failed to upload the deep params
Jasonr
Postby face_off » Wed Mar 21, 2018 2:11 am
face_off Wed Mar 21, 2018 2:11 am
As indicated above, you need to export to ORBX and see if you get the same error in Octane Standalone 3.08 RC2.
Postby Jasonr » Wed Mar 21, 2018 2:17 pm
Jasonr Wed Mar 21, 2018 2:17 pm
Hi Paul.
I have tested it already and it seems that the problem persists.
I cannot find the log in the standalone to upload the error.
GPU Fail
Jasonr
PreviousNext
Return to Graphisoft ArchiCAD
Users browsing this forum: No registered users and 8 guests
Fri Apr 19, 2024 12:29 am [ UTC ]
