OctaneRender 3 for ArchiCAD [OBSOLETE]
Forums: OctaneRender 3 for ArchiCAD [OBSOLETE]
Graphisoft ArchiCAD (Integrated Plugin developed by Paul Kinnane)
Re: OctaneRender 3 for ArchiCAD [TEST and STABLE]
Postby face_off » Thu Apr 27, 2017 5:07 am
face_off Thu Apr 27, 2017 5:07 am
the file you have posted seems to relate to the Revit Plugin?
Fixed now - thanks Dan.
Postby s3d-weyrauch » Tue May 16, 2017 1:38 pm
s3d-weyrauch Tue May 16, 2017 1:38 pm
Hi Paul,
I have to report a bug.
If I change the Y-Rotation of a Texture-Environment, than I have problems with importance-sampling, it misses suddenly the setting "behind the curtain". The importance sampling is on, but it seems to be not.
If I check the importance sampling out and on again, than everything will be fine again untill I change the Y-Rotation.
David
BIM team leader
Win 10 | ArchiCAD GER 23-24 | Octane Plugin for ArchiCAD
13 Licenses | Network Render over 12 graphic cards
s3d-weyrauch
Postby face_off » Wed May 17, 2017 3:52 am
face_off Wed May 17, 2017 3:52 am
Hi David - this is fixed in the next Octane release.
Postby Daniel_Ward » Wed May 17, 2017 5:00 am
Daniel_Ward Wed May 17, 2017 5:00 am
I noticed the same thing, thought I was going a bit mad.
+MAP Architects, Christchurch - New Zealand
ArchiCAD 4.12 - ArchiCAD 24 || Octane for ArchiCAD
i7-7700K - Gigabyte Aorus Z270X Gaming 9 - 32Gb RAM - 3x Gigibyte GTX1070 G1 Gaming - Window 10 64Bit
Daniel_Ward
Postby face_off » Sun May 21, 2017 1:32 pm
face_off Sun May 21, 2017 1:32 pm
I have updated the installers at the top of this thread with:
3.6.1.73
- Compiled with Octane 3.06.1
- The Reload proxy button now applies any "Face Camera" calculations
- The Reload proxy button now also works for OBJ proxies, so can be used to re-position a proxy after moving the proxy host
- Fixed issue where re-linking a missing proxy source file was not saving the new file name/folder back to the ArchiCAD scene
- Clicking the Reload button to reload a proxy now also reload the SCV scatter file
Postby face_off » Tue May 23, 2017 9:06 am
face_off Tue May 23, 2017 9:06 am
3.6.1.74
- Fixed bug with the proxy Reload button introduced in 3.6.1.73
Postby Jasonr » Wed May 24, 2017 9:35 pm
Jasonr Wed May 24, 2017 9:35 pm
Thank you Paul for the fast update.
Is there any possibility to be able to select more than one proxies, move them and have the option of a reload for all these moved proxies or is this a limitation between archicad and the plugin???
Thanks.
ASUS Z10 PE-D8 WS/2 x XEON E5-2680 V4/64GB RAM/1xQuadro M5000/2x NVIDIA GTX TITAN Pascal/ Windows 10/ Archicad 20
Jasonr
Postby face_off » Sat May 27, 2017 3:36 am
face_off Sat May 27, 2017 3:36 am
If you want to reload multiple proxies, you can just Refresh the scene.
Postby rappet » Sat May 27, 2017 9:48 am
rappet Sat May 27, 2017 9:48 am
My guess is the request is a feature to reload only the selected proxies, and not the total scene... To save time.
Which would be awsome, but I think hard to realize, right?
rappet
Postby face_off » Sat May 27, 2017 12:52 pm
face_off Sat May 27, 2017 12:52 pm
I think in a lot of cases it will be easier to reload the scene than to remember which proxies you moved and then select them all and then reload them. I am trying to understand the benefit of this change before I invest time in determining if it is viable.
PreviousNext
Return to Graphisoft ArchiCAD
Users browsing this forum: No registered users and 7 guests
Tue Apr 23, 2024 10:07 am [ UTC ]
