Make Custom LUTs work with ACES OCIO
Forums: Make Custom LUTs work with ACES OCIO
Tutorials for OctaneRender - demonstrations and howto's.
Postby lanklaf » Tue Jan 05, 2021 2:42 pm
lanklaf Tue Jan 05, 2021 2:42 pm
Camera Imager's "Custom LUT" option is not available in OCIO mode.
To use LUTs, you must convert them to OCIO LOOKs,
which can be selected in the OCIO Camera Imager tab:
How to convert LUTs to Looks:
For ACES config users
1) Drop your LUT files into the luts directory of the OCIO config
2) Add this code to the bottom of the config.ocio file:
looks:
  - !<Look>
    name: 1st Look name goes here
    process_space: Output - Rec.709
    transform: !<FileTransform> {src: lut_filename_goes_here.cube, interpolation: best}
  - !<Look>
    name: 2nd Look name goes here
  - !<Look>
    name: 3rd Look name goes here
Info:
- You can use almost any LUT file: .cube, .3dl, etc.
- The "process_space" should be the space your LUTs are for"
  • For regular Rec.709 LUTs, "process_space" is "Output - Rec.709"
  • For ARRI LUTs, "process_space" is "Input - ARRI - V3 LogC (EI200) - Wide Gamut"
  • etc.
You can also put your LUTs in a different folder.
I created a separate folder and named it "looks".
But if you do this, you will need to change this config.ocio line:
search_path: luts
to this:
search_path: "luts:looks"
Thanks @karu for sharing this information.
System:
i7 8700K / RTX 2020 / 16GB RAM
lanklaf
Re: Custom LUTs in OCIO / ACES workflow
Postby james_conkle » Tue Jan 05, 2021 10:50 pm
james_conkle Tue Jan 05, 2021 10:50 pm
Wow this is great!! Thanks for posting how to do this. Being able to get the same look in the live viewer and Resolve, without being “baked in”, is a total game changer. Before replicating the same look with the camera imager wasn’t always accurate.
Octane C4D Plugin 2021.1 / C4D R25.015
UNIT 0: 2080ti / 6700K / 64GB / 500w
UNIT 1: 2x 3090 / 3970x / 128GB ECC / 1600w
UNIT 2: 5500M / 9980HK / 32GB / 95w
RNDR Artist Calculator
james_conkle
Return to Tutorials
Users browsing this forum: No registered users and 7 guests
Tue Apr 23, 2024 10:27 am [ UTC ]
