Page 7 of 10
Re: Sculptron 1.0 - Alpha Preview Release
PostPosted: Fri Dec 13, 2019 10:10 am
by linograndiotoy
amandas wrote:
linograndiotoy wrote:
amandas wrote:This is the default view (deleted imgui.ini). Also, I will help you with debbuging this: when I changed taskbar settings to Auto Hide in Desktop Mode, suddenly the main menu bar appeared. I am guessing here this might be aspect ratio related. When I quit app and restart, the main menu bar is missing again (it reappears when I change taskabar settings).
Can you please try to press the Windows key+Left Arrow (to snap selected window to the left or right half of the screen) and see if you can see the menu bar?
That does the trick. Snapping to any border makes the main menu bar reappear.
Best!
Good! Next build will store the UI configuration correctly, so this should be solved.
PostPosted: Mon Dec 16, 2019 5:18 pm
by ramone163
When the next build will be released?
PS. When saving the project and open it - parameters do not save.
PostPosted: Mon Dec 16, 2019 7:23 pm
by andrey.krivulya
Hi, dear developers =)
Is it possible in Sculptron?
https://vimeo.com/379550189
PostPosted: Tue Dec 17, 2019 12:53 am
by linograndiotoy
andrey.krivulya wrote:Hi, dear developers =)
Not right now. For future releases we're thinking about something even better than that! ;)
by linograndiotoy
Very soon!
PostPosted: Tue Dec 17, 2019 7:28 am
by andrey.krivulya
Please add "Dynamic Triangulation" and 2x2080Ti with NVLink support =)
PostPosted: Wed Jan 08, 2020 9:12 pm
by matrix2012
Will there be a Linux version?
PostPosted: Mon Jan 13, 2020 3:53 am
by Notiusweb
Does Sculptron have cameras for different views / pans over a timeline sequence
PostPosted: Wed Jan 15, 2020 6:59 pm
by Alessandrobassp
Guys, it's not working... I've re-installed several times, or updated the cuda, but at 3d object display level it doesn't work well, at normal level and at shader display level... I don't really know what the problem is.
Please help me. I'm curious to try Sculptron.
PostPosted: Thu Jan 16, 2020 10:20 am
by linograndiotoy
Hi Alessandro!
What about your system configuration? Which OS are you using? Which graphic card?
