Another tip for AO
Forums: Another tip for AO
Tutorials for OctaneRender - demonstrations and howto's.
Another tip for AO
Postby PAQUITO » Sat Jan 05, 2013 3:29 pm
PAQUITO Sat Jan 05, 2013 3:29 pm
Adjusting the AO distance can be tricky. The shader is distributed uniformly all across the scene, so, there can be areas in the scene with an incorrect shading distance while it is correct in others. In general terms, evenly distributed spaces work best with AO. Check out this test:
In this test you can see a correct shading in the left object. In the object on the righ, the shading only works in the group of balls, while in the rest of the wall there are unshaded areas. The more you move from uniformity, the worse the shader works.
So, remember...
AMD FX8350 8 cores. 16GBs RAM
GTX690
Win8 64.
PAQUITO
Return to Tutorials
Users browsing this forum: Bing [Bot] and 1 guest
Fri Aug 14, 2020 8:54 am [ UTC ]
